I've been referred here by the afterdawn forum, hope you can help me.
I've got problems with playing .mp4 files and SOME .avi files. I've tried using VLC, KMP, WMP, Nero, PowerDVD.
.mp4 - out of sync a/v and glitchy video with VLC, KMP, WMP, Nero, PowerDVD v5 doesn't support mp4.
.avi - some of these play ok on VLC for a while then freeze up & go glitchy for a while. Those same avi's play ok on Nero.
Others are out of sync a/v and glitchy video (boxy, lack of resolution, green flickering outlines) with VLC, KMP, WMP & Nero.
PowerDVD plays all avi the best but on some has a/v sync issues.
Anyone give me any pointers.
Results 1 to 21 of 21
Haven't tried on another computer but some of them are files I've successfully viewed months ago so I know they're ok. I think its codec issue as I did have problems with codec pack compatibility so removed my codec packs and went to using individual codecs indicated by avicodecs & gspot. Hasn't worked out though.
Maybe try yet another player (MPC-HC). By default it installs using all of it's own internal splitters and decoders so if the files play okay in MPC-HC then I guess you need to look "outside the players", such as which decoders you're using etc. I think VLC uses all it's own decoders but I'm not sure about splitters and I've no idea what any of the other programs you're using do.
I think the out of sync problem isn't related to the avi file or player as my computer is low on virtual memory, CPU usage is at 100% & everythings running slow (eg Kaspersky scan ETA is 1 day). Don't know the reason for this, ran spyware S&D this morning & all was ok, malwarebytes a few days ago & no threats detected.
Check the process tab in task manager. Can you identify which process is using all the CPU?
The major user was avp.exe at around 310,000K, oddly avp.exe appeared 3 times in the processes list.
After that it was Firefox & Vuze. -
I've tested a wee bit and the cpu usage goes way down when not connected to the internet, this makes me suspicious - though a malwarebytes scan today shows all clear.
avp.exe iappears to be the kaspersky anti-virus program. -
If you turn off Kaspersky and disconnect from the internet, how do the videos play.
Ok, I've tested it out now. With internet disconnected .avi play fine on powerdvd, WMP-HC & Nero, they play on VLC but with persistent frame freezes & audi/video going out of sync.
.Mp4 doesn't play on any of the above as its got a/v sync issues, long freezes, poor video rendering.
Looks like there's codec issues with mp4 but otherwise its just a level of cpu usage issue - not sure why as previously I didn't have any problems with watching avi's while connected to internet with multiple processes running. -
I wouldn't rely on gspot. It hasn't been updated in 5 years. Try mediainfo. It doesn't suggest codecs to install, but I don't believe in that stuff anyway. I yanked all non microsoft codecs Smplayer and vlc don't need them, which is as it should be.
Anyway, vlc (which is my backup video program aftersmplayer) doesn't play vob dvd files well but it doesn't have much problem with mp4s. I don't use any non microsoft codec/splitter/filters that redirect away from directshow and I haven't had problems with video that wasn't broken or just really badly encoded.
I don't know where these videos came from but there are lots of bad videos out there. Installing more codecs will tend to make the problem worse and harder to trace.
You definitely seem to be having a problem with your antivirus. There are a bunch of posts on the kaspersky forums reporting maxed out cpus. This could cause more of a problem with mp4s encoded in h.264 format. They tend to use CABAC compression, which increases cpu load.
The remedy usually suggested on the kaspersky forum is to unstall and reinstall, but that wouldn't give me much peace of mind re the program. It's often a good idea to uninstall before doing a major upgrade ... say 1.0 to 2.0 rather than 1.0 to 1.1 ... but there shouldn't be those kinds of problems. I'd try it though.
Actually, while you may not want to hear this if you paid for kaspersky, I've yanked programs for much less problems. I use microsoft security essentials myself ... believe it or not, the tech support people at the user support dept in the local university recommend MSE. It's is the only antivirus program that doesn't cause problems on the network (false positives).
The thing about antivirus programs is that none of them really work anyway. When you read those reviews that say that one blocked 93% of viruses and another blocked 95% etc, what that really means is that they all let things through. -
You haven't posted your system details when you registered; please do that, CPU and clock, memory and operating system. Also, how much free hard drive space do you have?
Baldric said:
You would be smart trying this, if those files played smoothly on another machine it would tell you a lot where your problem is. If the files do not play on another machine they are probably corrupt, and then you had best find out why you are getting corrupted files on your machine.Have you tried those files on another computer? -
Thanks for the help guys,
Windows XP Service pack 3, Intel Pentium 4 CPU 3.40Ghz, 1 GB RAM, 232 HD Capacity 63.14GB free.
Not sure where to find the clock speed info, let me know and I'll post it up.
I've tried a few files and consistently mp4s don't play but I'll try to test one on another pc tommorrow.Baldric said:
The avi's seem to be ok - apart from cpu issues - but I'm fairly confident the mp4s are good as others have used them and I've seen no issues reported - that said I'll test on another machine myself.I don't know where these videos came from but there are lots of bad videos out there. Installing more codecs will tend to make the problem worse and harder to trace.
That's disturbing, hadn't heard about that before. I've been running Kaspersky for years (with updates) and its only recently there's been excessive cpu load. Not certain how uninstalling & reinstalling will help if the issue is the problem is kaspersky itself, presumably problem would just be reinstalled?You definitely seem to be having a problem with your antivirus. There are a bunch of posts on the kaspersky forums reporting maxed out cpus. This could cause more of a problem with mp4s encoded in h.264 format. They tend to use CABAC compression, which increases cpu load.
Still I'm happy to try uninstalling it but I'll leave that for a wee bit as a last resort.
Yeah, that's probably true, but I'd rather stop that 95% than let them get through so some form of antivirus is an essential for me.
Thanks again. -
I've tried one of the mp4s on another computer, took a while as the media player at my work didn't support mp4s but I checked on another computer & it plays ok.
So as here, I got issues on my player. I can’t play the videos on .mp4 and .avi format on my computer (surely the software was properly installed). But when I tried it on other pc it is working..What might be the cause?
Best & Fastest Tool To Cut An AVI, MP4 File In The Middle?
By onesikgypo in forum LinuxReplies: 3Last Post: 12th Oct 2013, 20:07 -
Playing HD MP4 Files From Disc Playback Issues?
By zombie1 in forum DVD & Blu-ray WritersReplies: 5Last Post: 5th Nov 2011, 11:41 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 08:35 -
Merge two AVI's & SRT's into one MP4
By vassie in forum Video ConversionReplies: 6Last Post: 18th Sep 2009, 04:00 -
.MP4 to .AVI Conversion Issues - Loss of Sound, Won't Run to Completion
By gumrunner505 in forum ffmpegX general discussionReplies: 1Last Post: 10th Oct 2007, 19:49
