These are the actions that I want to do:
a1: deinterlace mpeg 2 clips;
a2: crop 2 pixels from top, bottom, left, right;
a3: resize mpeg 2 clips to 16:9 resolution with square pixels and mod2 vertical resolution;
a4: denoise the clips, because they were recorded in low light and have alot of noise;
a5: import the clips in premiere pro cs3, edit them, adjust their tonality and color grade them;
a6: export with debugmode frameserver, and encode to progressive H.264, with x264.
Problems:
p1: I have no idea what codec to use. For example, if I use avisynth to deinterlace, resize, crop and denoise, then I have to use virtualdub to export to avi, but there are so many codecs: huffyuv, lagarith, ffv1, msu, cineform, dv and many others. All I know is that I should use an intraframe codec for editing, but I don't know wich one to use;
p2: I don't know what the best tools are for the actions listed above. For example, is sorenson squeeze better than avisynth + virtualdub ?
p3: I don't know what denoise filter to use in avisynth. How can I find the right denoise filter for the amont of noise ? Wich denoise filter is the best ?
p4: What is the correct order of filters in avisynth: deinterlace->crop->resize->denoise, or deinterlace->crop->denoise->resize ?
Here are the technical details of the clips, in case they are needed:
Code:General Complete name : F:\clip1.mpg Format : MPEG-PS File size : 15.0 MiB Duration : 20s 608ms Overall bit rate mode : Variable Overall bit rate : 6 093 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Duration : 20s 560ms Bit rate mode : Variable Bit rate : 5 716 Kbps Maximum bit rate : 9 400 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.551 Stream size : 14.0 MiB (94%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Muxing mode : DVD-Video Duration : 20s 608ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -120ms Stream size : 644 KiB (4%)
				Results 1 to 1 of 1
  Sony Vegas Pro - Importing clips from another projectBy ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 20:43
  Export HDV clips to SD clips from Premiere Pro CS3By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03
  Importing / Editting Edius AVI clips in premiere CS4By Wael in forum EditingReplies: 2Last Post: 15th Jun 2009, 09:31
  DVCPro 25/50 importing to Premiere?By LuckieGW in forum EditingReplies: 3Last Post: 1st Mar 2008, 20:59
  large file size when importing small video clips into Sonic MyDVDBy artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
