hello guys, i love this forum and i need you to help me a little bit with encoding
always when i try to encode a REMUX bluray .mkv which i have downloaded via torrent to avi via staxrip i get a iostream error or something, ALWYAS! do you know why and do you know how to fix this?
also i would like to know whats the sense of x264 xvid Movies, are they better in quality or what?
whats a H264 Movie, i saw this option in some encoders.
can someone give me a guide how to rip a complete bluray to 720p bluray?
what is better, AAC audio or ac3, because many use now AAC.
thanks and have a nice day
Results 1 to 15 of 15
Nero AAC is the best audio codec out there. AC3 blows ****, even MP3 scraps the floor with it.
You might have to reencode the audio to MP3/AC3. Why are you remuxing to AVI?
can someone give me a guide how to rip a complete bluray to 720p bluray? -
h.264 (AKA MPEG 4 part 2, AVC) is a more advanced video compression technique than Xvid/Divx (MPEG 4 part 2, ASP) which is a more advanced than MPEG 2. So h.264 can compress video more/better than those other codecs.
AVI is not a good choice of container for h.264 video. Stick with MP4 or MKV which are better designed to support advanced video codecs.
The best quality audio you will get is to retain the audio in whatever format it is on your source. Any re-compression with a lossy codec can only reduce the quality. So if you're ripping a DVD, keep the original AC3 audio track intact. If you're ripping a BD keep the original DD or DTS track(s). -
Murphy's law taught me everything I know. -
http://forum.doom9.org/showthread.php?t=161957 -
Love how Nero has the lowest bitrate on nearly every sample in that test.
Love how few participants it had.
Love how that is the first and only listening test on that site where Nero scores so low.
Love how it triumphs on every single previous test.
Love how you base your opinion on one single flawed test without the tiniest skepticism.
Besides, if I were you I would follow more reliable sources, like http://soundexpert.org/encoders-96-kbps where the testing methodology is considerably more rigorous and removes a lot more variables. Hydrogenaudio is full of autistic queers living in their moms basements and I would sooner trust my cat's ears than theirs. -
Actually, cats have much better hearing than humans. Getting them to take ABX tests is the hard part.
They can hear much higher pitches, and that's it. Our hearing is superior in every other way, so I certainly won't care about "high quality" 192 kHz DVD-audio, but I still buy them for my cat.
Thanks for all questions, will now use x264 Codec + AAC.
I try to encode now with Handbrake.
Can you explain this options for me:
Detelecine
Decom
Deinterlace, important?
Denoise
how much bitrate should i always use, 1500 is enough i guess?
there are many aac types, ffmpeg, passthru, faac, which one is the best and how much bitrate (448?) and samplerate (i think 48) should i always use? -
wouldn't be simpler to just start encoding with ripbot264 ? It is very easy to use.
Handbrake uses FAAC which is not very good in terms of quality/size.
RipBot264 uses Fraunhofer AAC encoder (Those guys invented MP3 if you didn't knowSo you don't have to worry about quality at all
64kbps for one channel is really enough. (128kbps for stereo and 320 kbps for 5.1)
Regarding video bit-rate. Take my advice. DO NOT USE 2-PASS mode unless you are aiming for specific size (CD / DVD)
USE CONSTANT QUALITY MODE instead !!! You will save time (only 1-pass!) and space. Encoder will automatically adjust bitrate according to video complexity and selected CRF value.
Good starting point is CRF@20
VERY IMPORTANT! LOWER VALUE means HIGHER QUALITY AND LARGER SIZE!Last edited by Atak_Snajpera; 30th Apr 2012 at 05:09.
i tried ripbot already and its great my friend
the only problem is i cant select multiple languages
i always make DUAL LANGUAGE rips and in ripbot i cant select 2 audio files otherwise i'd use it.
which profile should i use for good constant quality? progessive?
and 128 kbs fhg-acc-lc for best audio quality or? -
Handbrake Encoding Questions
By x22 in forum DVD RippingReplies: 1Last Post: 19th Oct 2011, 21:41 -
Questions about H264 encoding?
By Mr.Teflondon187 in forum Video ConversionReplies: 3Last Post: 21st May 2010, 02:02 -
A few questions on Anamorphic encoding
By scubasam in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2010, 22:04 -
a few encoding questions
By henhao in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2009, 18:57 -
Encoding questions
By helper in forum Newbie / General discussionsReplies: 4Last Post: 3rd Nov 2008, 23:58
