Anyone know how to make it so when I record with my mics the sound come in evenly on both R and L speakers? I use a canon hf-m40 Please help.
I have used 2 different mics and the result is the same: stronger sound in the right ear and weaker in the left. Are there settings on the camrea or is it something with the mics?
Most Canon HF camcorders have manual level controls for each channel in menus but not all. Check your user manual.
Turn AGC off if you have that option.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I don't have that option. IS there a way to do it in post production? I have Adobe audition and premiere.
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11 -
Camera - IEEE 1394, Compsite and mic in???
By djlerman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Jan 2012, 23:58 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 16:38 -
Need help buying a second hand camera with external mic
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 18th May 2009, 20:10 -
Looking for a payable cordless camera mic
By B-Twien Bytes in forum AudioReplies: 2Last Post: 8th Jan 2008, 13:09
