What capture cards (or graphics cards with video in) can do full NTSC 720x480 @ 29.97 fps captures using huffyuv for lossless encoding (Street price under $800).
From what I can gather, the AIW might be able to do it but needs a patched driver (an the link to that on cinax.com seems broken).
The specs for the ASUS videa cards say they can only do 702x480.
Sounds like the Pinnacle DV500+ can do this, but the card sounds a little flaky (or at least lots of people have trouble setting it up).
A combination like the Canopus DVRaptor plus the ACDV100 (or the Hollywood DV converter) could work, except I don't want DV compressed video.
Any other possibilities? What is the best choice in this price range for highest quality captures? Thanks for your advice!
Please state a specific "not-to-exceed" budget amount.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
He says it in his opening question I think.Originally Posted by Mirror_Image
Originally Posted by mpwr5 -
I'm capturing full NTSC video (720x480 @ 29.97) on an ATI AIW Radeon. (regular 32MEG Radeon, the Radeon 7500, 8500 etc lines are even better)
I'm using VirtualDub with huffyyuv and on my P4 I may drop 12 frames every 24 minutes of video. These are STOCK drivers, right off the ATI website.
It's a great option since the video card is good too.
Regards,
Savant -
Sorry, I "buried" the budget I had in mind further into my post rather than stating it up front. I wanted to compare solutions that were under $800 (but would not mind considering ones under $400!) (actual prices).Originally Posted by Mirror_Image
The Visiontek Xtasy Everything does a good job for me (<$200). I use it with Virtualdub and capture raw .avi at 720x480 with no dropped frames on an Athlon XP 1700+ system I built. It's o.k. for the casual gamer too as long as you don't need GeForce3 or 4's performance.
So he did! My mistake for not reading further.He says it in his opening question I think.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
The video capture card is only 1/3 the battle,... another 1/3rd is a very good CPU system (and operating system). The last 1/3rd is the energy and time you will need to "Tune" that system to your Capture card so it will work Properly. Once you have all of this,... Welcome to the Capture Club.
If you want a "Taste" of what some of the 1/3 is all about, look in the User Guides section of VCD Forums for a post I make called "How to Tune your system for ATI Capture"
Just reading all the things that can go wrong and do go wrong will give you a better understand of what you are about to "Step Into".
Bud"Technology",...It's what keeps us all moving forward.
Minimum CPU to capture full motion NTSC video with HuffYUV?
By NJRoadfan in forum Capturing and VCRReplies: 12Last Post: 25th Mar 2012, 01:13 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53
