How do I get my LG RHT497H to recognize mp3's on the USB drive?
The specs say nothing about MP3s from a USB device. It says:
http://www.lg.com/uk/tv-audio-video/video/LG-digital-tv-recorder-RHT497H.jspMP3 CD-R/RW -
"There's no net connection, but you can play DivX videos, and JPEG, MP3, WMA and MP4 files off a USB key."
http://fwd.channel5.com/gadgets/audio-video/video/freeview-receivers-and-recorders/lg-rht497h
No idea why yours can't. Have you actually transferred them to the USB stick? -
Best guess - make sure your USB device is using FAT32 (best) or FAT16 (less good) as its file system. Anything else is unlikely to work.
The link provided by hech54 does NOT explicitly state that MP3 playback via USB is supported. It may or may not be. If you are using FAT32 or FAT16 on your USB device and it still won't recognize the files, then you will have to contact LG and get them to clarify whether they really support MP3 playback via USB or not. Many DVD players actually do not support playback via USB and use it only for things like firmware updates.
LG RHT497H - copying from DVD to hard disc
By jollysuper in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Apr 2012, 04:59 -
LG RHT497H DVD recorder - XP not reading DVDs made
By jollysuper in forum Latest Video NewsReplies: 2Last Post: 28th Mar 2012, 11:01 -
Recording issues with LG DVB-T HDD/DVD Recorder RHT497H
By Geex360 in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2010, 09:43 -
(pal) LG RHT497H - Can it record NTSC?
By dave_van_damme in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Nov 2009, 11:59
