Hello All,
I have purchased a WD TV Live Hub that has 1 TB of internal storage.
I have about 500 DVDs ripped (actually authored by me from TV Captures of Black & White movies via Canopus ADVC 110). Since the space available on WD TV is only 1 TB, I can place only about 200 DVDs on it.
I would like to compress my DVDs into such a format that I can place more movies on WD TV for watching. Quality should be near identical to the DVDs. All the DVDs are Black & White movies (only a bunch of them in eastman colour) and all are 4:3, sterio audio only.
Which format you would recommend? And also, which free software to use for conversion?
I would be pleased if I can 'convert' the DVDs into a format which reduces each movie to about 1 GB or less.
The WD TV can play almost any format, including mkv, H.264...etc, with the exception of DV AVI, and Real Media files.
Many thanks.
Ok. These are not any latest blockbusters, just old black & white movies. So I can settle for reasonably good quality.
I believe the recent WD TV models like this one can also play files via a network if that is useful to you. And you don't have to use the internal storage. It supports USB so you could put your files on a larger external drive and attach it via USB if you wish. Do get a USB enclosure that contains its own power supply if you try that.
If you still want to convert, Handbrake might be a good option for you. It uses H.264 to encode the video. If your audio is AC3 then I would leave that alone if Handbrake allows you to do that. If your audio is LPCM then to save space you should let Handbrake convert it. -
h264 plus the original AC3 audio in an MKV container. 1 GB is pushing it but doable. I recommend Handbrake too. Pick a rate factor (quality level) that you are happy with and just use that to encode all your videos. 18 to 20 is probably a good range. The higher the value, the lower the quality and file size.
jman98 & jagabo, thanks for the advice. I tried Handbrake, with MKV container. Final size is 1 GB per movie. The movie looks fine on the computer screen. Considering the fact that it is compressing an already compressed DVD folder, the quality seems to be fine. Also, I like the fact that Handbrake doesn't require me to merge all VOBs into one single VOB. It directly understands the VIDEO_TS folder structure and does the job. There seems to be a batch feature too.
I will put it on the WD TV and see how it upscales it onto my 40" HDTV via HDMI. -
Look in dark noisy areas of the video. That is where x264 has it weakness. See the samples in this post:
https://forum.videohelp.com/threads/345427-Handbrake-Should-i-leave-it-on?p=2156674&vie...=1#post2156674
WD TV Live Hub First Impressions
By TBoneit in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Nov 2010, 15:09 -
New WD TV Live Hub
By stiltman in forum Media Center PC / MediaCentersReplies: 8Last Post: 4th Nov 2010, 14:25 -
using NTSC TV as external monitor to watch PAL dvds played on laptop
By billybadbreaks in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2009, 14:27 -
I want to watch PAL formatted, Region 2 DVDs in the USA.
By Lori in forum DVD & Blu-ray PlayersReplies: 18Last Post: 10th Jul 2008, 19:39
