I have been successfully making SVCD's for a while now and am trying to improve by experimenting a little. What I am trying to do is encode a movie to 23.976 f/s and use 3:2 pulldown in TMPGEnc 2.5. The problem is that when I use these settings under the "Video" tab, it makes the encoded movie "non-interlaced" and it doesn't play correctly in my DVD player on my TV.
I also tried to use the settings...
Frame rate: 23.976
Encode method: Interlace
And under Advanced selecting "3:2 Pulldown".
This didn't work either, It was still progressive.
So, does anyone know how to make a move with 3:2 pulldown but interlaced? Or have any other suggestions?
My DVD player is an APEX 5131.
Thanks,
Tearren
Results 1 to 12 of 12
i had a movie encoded as pal, and to convert it to ntsc, i chose 1:1 as source and converted as usual by choosing ntsc in project wizard
it worked... no lines when things moved -
try 3:2pulldown when playback option
when hell has no more room the dead will walk the earth -
its under settings-encode mode not the advanced options leave that 3:2pulldown box unchecked
Hey Compound,
Thanks for the reply. Actually, I am choosing the 3:2 pulldown option, but when I play the movie on mt tv with my dvd player, I can see lines. This is because with 3:2 pulldown the movie is made to be progressive. It even says in TMPGEnc in the description of 3:2 pulldown that encoding is done with non-interlace (or progressive). I need it to be interlaced, because I don't think I can play a progressive movie or I'll see lines. Right??? Any other suggestions?
Tearren -
whats the framerate of the origanal file
The frame rate of the original is 29.97 (Checked with Bitrate Viewer).
When I frameserved with DVD2AVI it was 99% Film. If I understand correctly, I should be able to make the frame rate 23.976 with 3:2 PullDown. Right? -
try the pulldown when playback option that should make it standard svcd at29.97 fps i dont understand how your gettin progressive it shouldnt change try the new tmpge 2.53 it works better than previous versions maybe theres a bug or somethin
Thanks for the suggestion!
I'll do some testing with a newer version. -
just the oposite you want 29.97 for svcd if you want to change origanal 29.97 to 23.97 you need to inverse telicine but if the origanal is 29.97 just leave it alone for svcd (no 3:2 pulldown)when hell has no more room the dead will walk the earth
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Encode in Interlaced or Deinterlaced w/Pulldown?
By CubDukat in forum Video ConversionReplies: 4Last Post: 19th Jun 2011, 18:29 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Just What Does 'interlaced Mode' do in Magix Movie Edit Pro 12?
By gom in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2009, 14:10 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 11:54
