Hi,
I have found that it is impossible top add subtitles to MKV's. I can easily add them to AVI or MP4 but whenever I try to add a SRT or ASS file to my MKV's they never work. I have tried using MKVToolnix to add them with no success. If I "add" the sub to my MKV all I get is a black screen with the audio playing in the background. If I "append" the sub the video freezes completely. I have tried this on different video files with the same results. For a container that is supposed to be the most advanced it sure is lacking when it comes to subtitles. As I have stated MKVToolnix is of no help. If anyone is aware of a workaround to add sub files to MKV's please let me know.
Results 1 to 12 of 12
I've never had a problem adding SRT subs to MKV files with MMG from MkvToolnix. What player are you using?
How do you play the video? Software player or standalone media player?
I think that may be the problem. I am using KMPlayer. I tried the "added" sub to a newly created MKV using MKVToolnix and VLC player seems to be playing it without a problem. This is odd since KMPlayer is supposed to just as compatible as VLC if not more because of the number of configurable options it includes.
I'm encoding the MKV for use on the PC but I'll keep that in mind if I need to encode for devices.
ThanxLast edited by default_user; 26th Apr 2012 at 02:08.
.TS to MKV - What makes this conversion so difficult?
By Tiernan in forum DVB / IPTVReplies: 33Last Post: 13th Jan 2013, 10:06 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Adding subtitle(s) to a DVD for the first time
By 2298 in forum Authoring (DVD)Replies: 2Last Post: 30th Aug 2011, 05:15 -
Adding time values into video or as subtitles
By Heliooos in forum EditingReplies: 1Last Post: 23rd Apr 2010, 04:54 -
Adding record time on captured tv
By cylo in forum EditingReplies: 6Last Post: 2nd Aug 2009, 22:56
