Please consider supporting us by disabling your ad blocker or buy PlayOn and record Netflix! :)
Results 1 to 9 of 9
  1. To play 5.1 content on stereo speakers, does one need the media player to downmix it? Some players by default like VLC indicate that 5.1 audio is played as stereo as it uses "windows default" while others like mpc just play it as 5.1 unless you tell it otherwise. Is it best to have the media player or its filters downmix or just have the speakers/sound card do that automatically? using x-fi.
    canada
    Just set the audio to stereo in the creative control panel,it will be downmixed.
  3. Originally Posted by johns0 View Post
    okay thanks.
  4. all audio processing since Vista is made by CPU in software even if audio cards is able to perform hardware processing.
  5. Member Cornucopia's Avatar
    ...NOT counting proprietary DSP cards such as AVID/Digidesign's ProTools HD/Accell ($$$$). Those totally bypass the OS's A/V infrastructure and use their own.
  6. Don't have any experience with this particular audio card but seems that it will work outside MS DRM scheme.
  7. is there any way to find out who is downmixing?
  8. I'm a Super Moderator johns0's Avatar
    canada
    With openal games that support it work in hardware mode for sound in vista and windows 7.
