Has anyone gotten the hot keys to work? Everytime I try to use them, my machine crashes and restarts itself!![]()
Do you mean hot keys such as <ctrl>+<up/down arrow> to change display window size and F3 to hide/display the frame around the TV display?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
no, the ones that you can define so that you can watch a movie on the monitor or the TV. If you enable the hot keys you don't have to right click on the desktop, click properties, click the settings tab, then click the advanced button, then click the displays tab, then click the enable tv display button.
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
Done clean install of Win 7, cant get hot keys to work
By Tbag in forum ComputerReplies: 2Last Post: 19th Feb 2010, 12:36 -
Which keys are simulated?
By blagus in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2009, 09:20 -
Lost CD Keys, need replacement software Freeware
By Mboyle in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2009, 16:32 -
Dual Boot OS use 1 or 2 keys?
By johnhammonds in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 06:20
