Hello,
I have this video that's WMP v9 encoded. I would like to convert it to divx/avi so that it is able to play on a DVD player. I have tried numerous conversion programs, but the end result is the converted video will NOT play normally.
Does anyone have this experience before and how did you resolve it?
Thanks in advance for your help!
Regards,
Eric
Results 1 to 13 of 13
Also, you'd better define whay you exactly mean by "the resulting files are not played 'NORMALLY' ".
Playback starts and suddenly freezes?
Playback has "hiccups"?
Audio goes out-of-sync?
Generally speaking, WMV files created by Media Encoder 9 and Movie Maker, or which are split/joined improperly,
do have Variable Frame Rate
a problem that I like to kill
through Avisynth
Below is the output you requested. The symptoms are
Playback starts and suddenly freezes? Yes, definitely!
Playback has "hiccups"? Yes, definitely!
Audio goes out-of-sync? Can't tell
Any idea what the problem is and how to fix it?
Eric
General
Complete name : C:\Documents and Settings\user1\My Documents\My Videos\Video.wmv
Format : Windows Media
File size : 1.19 GiB
Duration : 1h 24mn
Overall bit rate mode : Constant
Overall bit rate : 2 026 Kbps
Maximum Overall bit rate : 2 080 Kbps
Encoded date : UTC 2012-04-09 02:10:40.140
Application : Windows Movie Maker 2.1.4026.0
Video
Format : VC-1
Format profile : MP@ML
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 1h 24mn
Bit rate mode : Constant
Bit rate : 1 900 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate : 29.970 fps
Standard : NTSC
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.183
Stream size : 1.12 GiB (94%)
Language : English (US)
Audio
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9.2 - 160 kbps, 44 kHz, stereo (A/V) 1-pass CBR
Duration : 1h 24mn
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 96.2 MiB (8%)
Language : English (US) -
Hi
FFmpeg will do the job.
From here ---> http://ffmpeg.zeranoe.com/builds/
Code:ffmpeg -i Video.wmv -c:v mpeg4 -b:v 1800k -vtag divx -c:a libmp3lame -b:a 160k Video.avi
First, try the following:
which should generate a video-only file.Code:ffmpeg -i Video.wmv -c:v mpeg4 -b:v 1800k -vtag divx -an Video1.avi
Then, try wma2wav on the original "video.wmv"
http://code.google.com/p/mulder/downloads/detail?name=wma2wav.2011-10-01.zip&can=2&q=&sort=-uploaded
Third, convert the intermediate .WAV to mp3, and finally,
mux both Video1.avi and Audio1.mp3 into the final Video.avi.
IF the method suggested above doesn't work for you,
then come back and complain again
H.T.H. -
WAV takes up more space, a LOT more space, than MP3. But there's no reason you couldn't use it if that's not a problem for you.
Technically, you can have an MPEG3-compressed WAV (a valid WAVE file, with proper header, but using MP3 compression). Of course, if you're going to use that for creating an AVI audio stream, that would beg the question why you wouldn't go ahead and use an MP3 audio stream in the first place.
Then again, you might not want to risk degrading the audio by compressing it to MP3.
convert .divx to .avi
By ad_jack in forum Newbie / General discussionsReplies: 15Last Post: 10th Feb 2013, 09:27 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
is there a simple way to convert an avi to vcd?
By lks9042 in forum Newbie / General discussionsReplies: 8Last Post: 10th Dec 2009, 04:00 -
WMV has no video on my TV out on "WMP v9 (VC-1 Simple/Main)"
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2008, 06:08 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
