Hi everyone,
Newbie here.. but very familiar with certain files formats for videos. I've been trying to demux 720p HD MKV files with TSMuxer in m2ts format for editing in Sony Vegas 9. Every time I drag the demuxed m2ts (and every other file option on TSMuxer) file into Vegas, it only has an audio stream.. I can play m2ts files from Blu-Ray's just fine in Vegas. I did convert them to MP4 files and they worked.. but a few frames got really messed up. Those were not present in the source MKV file.. Any ideas on what is wrong with Vegas or the m2ts files?
Here is the info on the video/audio:
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : N=1
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 0s
Bit rate : 3 996 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 629 MiB (89%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 22mn 0s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 60.5 MiB (9%)
Language : English
Default : Yes
Forced : No
I tried TS, still have the same issue. Is there a format that I can convert it to without little-to-no quality loss?
Vegas 9 is quite old and still might have some issues with H.264, better is to test latest release,
BUT, I myself have Vegas 8 and load H.264 because I have ffdshow installed. I can read in properties for clip that ffdshow is reading that file, some mp4's. It reads avi with H.264 in it too. Mp4cam2avi changes my mov container from photo camera with H.264 into avi and then I load it into Vegas. -
It can load mp4 with H.264 but could be very particular sometimes it will not load audio sometimes audio only, so I could test some samples over past years, I don't know what settings Vegas doesn't like or likes, perhaps even programers don't, they just trouble shoot camcorder videos, or formats they were told to. Camcorder videos and similar. Obviously they do not troubleshoot for all kinds of variations for H.264 parameters and containers at the same time or they might even sabotage some , what do we know
. Heck, even version 11 for some reason will not smart render progressive HDV same way as in previous versions so if I want to smart render my 30p I have to use older version. So stuff can get weird , could differ from version to version.
you can cut some 20 seconds or so (mkvmerge, set split after 20 second and then stop the proces) and post it
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 13:55 -
Vegas Pro 9.0 (64bit) won't see installed Filter/Plug-In
By mltwitz in forum EditingReplies: 1Last Post: 26th Aug 2010, 14:16 -
importing x264 mkv files into Sony Vegas 9
By pred in forum EditingReplies: 0Last Post: 26th Jul 2010, 14:12 -
Converting MKV causing trouble in Sony Vegas
By DaveFresco in forum Video ConversionReplies: 3Last Post: 4th Jun 2010, 05:23 -
Sony Vegas conversion help
By IcanslamatornadoRew in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 00:52
