I have a DVD motion menu I created in AE CS5.5. I then imported it into Encore for authoring. However, my menu is 15:10 seconds long, which is what I intended. My loop point is at 14:14 seconds. When previewed, the music track is also looping, which I guess should happen. But since the menu is looping at such a short time lapse, the music sounds like it is being cut-off-and-on, off-and-on, off-and-on, etc.(Well, you get the picture).
Is there a way, if applicable, to have the music simply continue while the video loops? (If there is a solution, it will probably have to be done in After Effects).
Your thoughts.
Thank you in advance.
AFAIK the answer is no since the audio is linked direct to the video - ie in the same vts.
If you want a longer piece of audio to go with a shorter length of video, a fudge would be to lay several lengths of video - your 14 or so seconds - on a video track in an NLE with audio to match the entire length.
You then loop the menu - the long video - at the end so the music only cuts out one time in x where x in the number of times the video has been repeated in the track in the NLE -
Just a little follow up.
There does exist an advanced technique, available with some authoring software, called 'Inverse Selection'
What that does in practice is alter the video content according to the position of the selector on the menu but the audio is un-affected.
There is no actual looping just different elements of the menu become visible as you navigate the menu. -
Or one could use Audition/Soundbooth to do a fade-in with a fade-out for the expected loop-point. It may not be as elegant as the advanced technique, but it would not be as abrupt as simply cutting in and out.
The more you learn, the less you know. -
Actually, JimJohnD, et al, the fade-in and fade-out of the music track, as you indicated is a good idea. I don't mind that it is not elegant. In fact, many Hollywood DVD menus play in that fashion.
As for the other suggestions in the post I will inquire about all of them. Since I am relatively new to After Effects and Encore, I need all of the knowledge and assistance I can receive.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Authoring Blu Ray in Encore
By Vasilis in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Nov 2011, 12:44 -
Bluray Authoring with Adobe Encore
By jrodefeld in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jun 2011, 19:06 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 16:03
