Ok - I have a 1080p encode, see details below.
Type: Video
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Resolution: 1920x1080
Frame rate: 23.976023
Type: Audio
Codec: MPEG AAC Audio (mp4a)
Language: English
Channels: 3F2R/LFE
Sample rate: 48000 Hz
When I open this up in Staxrip and prepare for re-encoding (lets say to another .mp4 or even .mkv) when I configure the audio to read:
Codec: AAC
Mode: VBR
Profile: Automatic
Channels: 6 (5.1)
Sample Rate: Original (or 48000Hz)
Bitrate: 256kbps
Quality: 0.40
The resulting encode has perfect picture but absolutely no sound? i.e. Opened it with VLC, checked codec info, Video info is as above, but Audio isn't even listed?
Any ideas?
Also - if I can tag on one other question? Anyone know of a quality program to edit .mp4 video? I have two separate files that I need to trim a few minutes off each and then join them to make one complete (edited) file. I have tried VideoReDo, Yamb, avidemux, Solveig, and all the usuals - but none of them work properly. (i.e. they are either not frame accurate (or even close to accurate) or in the case of VideoReDo - it somehow changes the framerate from 23.976023 to 23.980815 ???
Thanks in advance.
Hi Baldrick,
Thanks for your reply and for sorting out my thread. Sorry about the cross posting - I realised that I posted in the wrong section, but couldn't find a way to delete the thread.
Anyway, I'm not 100% sure what you mean: "Are you copying the audio in staxript?" I am opening the complete file (video & audio) in Staxrip, it is scanning the contents of the file like it normally does and then I get to the usual page where I can edit (crop, resize, file size, etc.) I set everything up like I normally do, select my container (.mp4 or .mkv) and set up the audio.
I've done this a million times with loads of file - all without issue. It's just as soon as I try to obtain 5.1 AAC (from a file with 5.1 AAC to begin with) I end up with no audio at all????
If you can shed any light on this - I would be very grateful for your help. Alternatively, do you know of a program which can edit (frame accuracy) a .mkv file? I've tried the one's about without any luck.
Thanks in advance. -
Baldrick,
P.S. I can select AC3 (5.1) instead of AAC (5.1) and I get perfect sound - it just progressively goes more and more out of sync the longer the movie goes on - i.e. it's not always just -200ms out of sync - it keeps changing. Hence why I'm wondering why I can't get AAC 5.1 - if the original file had AAC 5.1 ???
Thanks.
Video/Audio out of sync after using StaxRip
By supernano in forum DVD RippingReplies: 1Last Post: 23rd May 2011, 23:30 -
Staxrip (two audio tracks)
By denadel in forum AudioReplies: 1Last Post: 30th Apr 2011, 19:40 -
StaxRip: editing on the audio
By elmuz in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2010, 09:29 -
Staxrip giving me audio files
By JBWhiteley1 in forum DVD RippingReplies: 0Last Post: 11th Jun 2008, 00:10 -
staxrip audio question
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2007, 22:42
