  1. Are there any external capture card will do AVI so I can make VCDs? I've tried mpeg1 using Dazzle DVC with not so good results. I just got the Hollywood DV-Bridge and will try mpeg2, but I heard that is not good also.
    I need an external card because I'm using my laptop.
    Thanks,
    Jul 2001
    Maryland
    AVI is to big for the USB bus n u will get bad captures.
    best bet is the firewire Dazzle DV bridge, it does DV
    the USB 1.1 Bus can hold 12 megs
    the Firewire Bus can hold 400 megs
