I want to know what color range im supposed to set up for dvd or TV rips, since they are made for TV does that mean I need to have the GPU or player be 16-235 and not full range? Also take VLC, it got an option that converts YUV to RBG by default; so won't it be easier to just deselect it since doing so gives colors close to 0-255 i think. I'm confused by it, having it on makes the video washed out, but the name of the conversion implies its taking TV material and amending it for PC. surprisingly uncheckin "Use Hardware YUV-RGB Conversions" appears as the equivelent of 0-255. Now I don't know what to go with, GPU options or software like VLC. Its worth noting the problem is with VLC only it seems.
	There's no such thing as a "TV rip".
 To "rip" a DVD means you extract data unchanged off the media. (NO ENCODING!) Otherwise it's not a "rip".
 NTSC video is YUV, not RGB, and has color ranges specified by the format in use. (NTSC, ATSC, etc)
 So your question doesn't really make any sense.Want my help? Ask here! (not via PM!)
  Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44
  Red replacement in RBGBy drmrsolds in forum EditingReplies: 3Last Post: 29th Sep 2009, 08:07
  YUYV/YUY2 signed/unsigned, RBG and "usual" values questionsBy Guimauve2 in forum ProgrammingReplies: 0Last Post: 8th May 2008, 19:15
  HDMI cable seems worse than RBG cableBy BroomQueen in forum DVB / IPTVReplies: 7Last Post: 24th Dec 2007, 18:27
  Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan settingBy ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
