Hi,
I have a trange problem. I encoded a Space 1999 DVD in mkv format by using HandBrake.
When I'm looking to the videos, I'm seeing the image shaking a little bit. I mean the image is like freezing (jerky) a very small fraction of second then being fluid for a time. I took a Zone 2 PAL DVD and convert it to Zone 1 NTSC. All the time the image is perfectly clean.
Any help will be welcome.
Général
Unique ID : 193673884031470206342387802462611421460 (0x91B43BB7988391FFEBE43A686D51B914)
Complete name : C:\Users\Client\Videos\Cosmos 1999\Cosmos1999.1x05.Direction Terre (Earthbound).FR.LD.mkv
Format : Matroska
Format version : Version 2
File size : 445 Mio
Duration : 50mn 10s
Overall bit rate : 1 239 Kbps
Writing application : HandBrake 0.9.6
Writing library : libmkv 0.6.5
Vidéo
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Oui
Format settings, ReFrames : 4 images
Codec ID : V_MPEG4/ISO/AVC
Duration : 50mn 10s
Width : 698 pixels
Height : 576 pixels
Display aspect ratio : 1,292
Original display aspect ratio : 1,293
Frame rate mode : Variable
Frame rate : 23,976 Im/s
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressif
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : Anglais
Default : Oui
Forced : Non
Coordonnées de chromaticité : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Caractéristiques du transfert : BT.709-5, BT.1361
Coefficients de la matrice : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 50mn 10s
Channel(s) : 2 canaux
Sampling rate : 48,0 KHz
Compression mode : Avec perte
Language : Français
Default : Oui
Forced : Non
Thanks,
François
leave it at 25fps pal if you don't want visual problems caused by frame rate conversion.
Your resolution is too large for NTSC video. I do not use Handbrake so I cannot comment on that, but conversions between PAL<->NTSC frame rates in either direction can result in what you are seeing. I do not know how the source PAL DVD was created but given how many production houses botch this kind of thing, there is always some chance that PAL DVD was produced in a non-optimal way, such as converted from an NTSC master rather than a film frame rate master. You may wish to post a very short (10-15 seconds) excerpt from the original PAL DVD as some here can examine it and determine what exactly you have to deal with and whether this kind of conversion can be done any better in Handbrake if you really must produce NTSC compatible output from it.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
DVB-S2 - TS file plays fine, jerky when muxed to MKV
By DragonQ in forum DVB / IPTVReplies: 0Last Post: 16th Dec 2011, 15:58 -
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55 -
Subs getting altered when converting DVD image (iso) to mkv in HandBreak
By Ronin Silfar in forum SubtitleReplies: 5Last Post: 5th Feb 2010, 03:26 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34
