Closed Thread
Results 1 to 12 of 12
    May 2004
    Chicago South Suburbs
    I have files of movie that I downloaded. Sampled them extensively, and, they are in sync. yet when I convert, and, burn them to DVD using AVS to DVD, first having the completed product built as an ISO file, and, burned using the latest version of Img Burn, or, just having DVD structure files created, and, burned using the latest version of Convert x to DVD, the finished product is out of sync.
    I have had problems before when original files that are in sync, come out of out of sync when converted and burned with Convert X alone, and, was advised to try AVS instead. Usually that will solve the synchronizing problem, but not in this case.
    Both files are .avi with XVID.
    Can someone (Baldric, maybe,) help me out with this?
    Baldrick....
    Post the full details from the avi. Use Mediainfo.
    May 2004
    Here is basic info.
    avi (open DML) 1.06 GiB
    1 video stream MPEG-4 visual (xvid)
    1 audio stream MPEG audio (mp3)
    1st video stream 1 564 kps 680* 384 (16:9) at 29.641 fps. MPEG-4 (XVID) (packed bitstream) (advanced simple at L5) (BVOP2)
    1st audio stream 192 kps 44.1 khz 2 Ch. MPEG audio (mp3) (v1) (Layer 3)
    Oct 2005
    666th portal
    mediainfo is free. use it in text mode and copy paste the results as you were asked to. not enough info.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    29.641 fps doesn't sound good
    Oct 2005
    666th portal
    might be vfr, but hard to know.
  7. burned using the latest version of Convert x to DVD, the finished product is out of sync.
    In Settings>Audio, did you try setting the 'Do not fix audio discontinuities' flag?
    Indiscernible audio gaps can pose problems if the audio stream has been badly encoded.
    It's worked for me a couple of times.
  8. Originally Posted by agent222 View Post
    Post the AVStoDVD project log file
    Bye
    MrC
    AVStoDVD Homepage
    May 2004
    General
    Complete name : C:\Users\Bill\Downloads\{www.scenetime.com}The Three Stooges 2012 TS Xvid- Vrxuniique\3s-Vrxuniique.avi
    Format : AVI
    Format profile : OpenDML
    File size : 1.06 GiB
    Duration : 1h 26mn
    Overall bit rate : 1 764 Kbps
    Writing library : MPlayer
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 2
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 26mn
    Bit rate : 1 564 Kbps
    Width : 680 pixels
    Height : 384 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.641 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.202
    Stream size : 965 MiB (89%)
    Writing library : XviD 64
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 26mn
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 119 MiB (11%)
    Alignment : Split accross interleaves
    Interleave, duration : 498 ms (14.75 video frames)
    Interleave, preload duration : 500 ms
    Writing library : LAME3.98.4
    May 2004
    this is another file of the same movie that I have had the same problem
    General
    Format : AVI
    Duration : 1h 26mn
    Video
    Codec ID : XVID
    Duration : 1h 26mn
    Width : 680 pixels
    Height : 384 pixels
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : MPEG Audio
    Codec ID : 55
    Codec ID/Hint : MP3
    Duration : 1h 26mn
    Bit rate : 192 Kbps
  11. There's your problem. The DVD isn't released until august 2012. You have bad sound because it doesn't exist yet.
  12. I'm a Super Moderator johns0's Avatar
    canada
    Wait for the legal release,this thread is closed.
