Hi,
I have a LG Flattron w2253v monitor. I aslo bought a saorview approved set top box. (saorview = irish free to air digital television)
I connect the 2 with HDMI.
It worked perfect first time, 720p and 1080i.
But since then randomly it will not work. The monitor says HDMI power saving mode. i read somewhere about pin19 on HDMI, so I plucked that bad boy out. Still no good.
However, my neighbour's PC will work connected via HDMI to the monitor, and then my set top box will work after! Then unplug the lot and it won't work when plugged back in.
This is really annoying. maybe I need to cut pin 19 wire altogether? If so are they color coded? Could someone give me the short and nasty of HDMI pins and which one does power saving/handshake/tickling that might cause the monitor not to hear the set top box?
All help is appreciated.
Look at me go...
http://www.blueechosolutions.com/info/hd-ez-lock/repairing-damaged-hdmi-cable/
so no color coding and i dont have a multi meter with me. looks like no tv tonight... -
Nothing in the LG Flattron w2253v spec suggests support for 1080i, only 720p/1080p. Computer monitors generally don't support interlace.
Get 720p working first. Then if your set top box supports 1080p out, try that.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks for the reply.
Here's the wierd thing.
If i unplug the vga and connect the set top box alone I can get it to work. But it requires me to have the set top box on and on a channel before I change source to hdmi. I have murdered the pin 19 on the hdmi and now it works as long as both hdmi and vga are not plugged in. Also 1080i displays perfectly as far as I can see.
So if someone else has this problem, plug in hdmi alone and have it playing something. Then change source on monitor. This worked for me. I'll try with a un-molested hdmi cable and report if pin 19 has anything to do with it. -
I looked at the US version of your monitor, and it has analog video inputs like a TV. This means it is essentially a tunerless TV, which is why it works for 1080i input. A typical monitor wouldn't display 1080i.
I have to say I'm very happy with this monitor and although tv isn't quite right color wise, it is easy to watch. The big advantage for me is turning the monitor on its side gives a pretty good A4 of reading.
I suppose mu original problem is just a quirk of my particular set top box and monitor situation. I hadn't realized that hdmi has different protocols and is inherently "different" to vga. Not that I really need to understand it in depth.
Sometimes I need to remember the good old days of trying to clean and get tracking right on VHS, or trying to jiggle an antenna on a roof. Or even, going into town to use the dial up internet..... -
I located and downloaded the manual for the UK W2253V monitor. I thought I might find something about disabling the HDMI power saving mode, but had no luck. I guess you are stuck with it.
The UK version doesn't have component video inputs, like the US model I saw earlier, but page A27 indicated that 1080i was still supported for the monitor's HDMI connection.
Is there a way to control a TV set top box over a LAN?
By True Colors in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2011, 12:00 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 12:48 -
HD Set Top Box- Teething Issues...
By bettytron in forum DVB / IPTVReplies: 2Last Post: 30th Dec 2008, 02:32 -
Converting discs made on a set top box.
By mtdg in forum DVD RippingReplies: 3Last Post: 20th Sep 2008, 15:51 -
Recording digital tv via a set top box
By rapattack in forum DVB / IPTVReplies: 4Last Post: 16th May 2008, 09:28
