Hi... I want to ask something...
Yesterday, I record video use webcam at my laptop.. But when I record, my laptop lag... So, i shut down...
When I opened, I see 2 video file, Capture_20120415.AVI (2 byte) and Capture_20120415.avi.part (1,88GB)...
But that file can't opened...
Anyone know how to opened that file? because I need that file..
Thank's for all...
Copy the big file (so you don't screw up the original) then rename the copy something.avi. See if that plays.
Try Virtual Dub and Avidemux.
This often works for files that have been truncated:
If it plays but reports errors, you can save it as a new AVI file -- in VirtualDub use "direct stream copy" and in Avidemux have both video and audio set to "copy".
That will rebuild the file with indexes so it should play normally. -
Thank's for it.. I already changes it to .avi, but it's can't work...
VirtualDub and Avidemux is same.. When I want to opened, that write The File "xxx" is of an unknown or unsupported file type...
Have any software or what to opened?
Thank's... -
I suspect the AVI header structure isn't filled out. If so, it will require more sophisticated techniques to fix. Like making another recording with the same device with the same settings and approximately the same length, then copying (with a hex editor) the AVI header from that file to the bad file. Then you'll probably have to use one of the AVI recovery tools like DivFix.
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
How to apply a filter to just a part of the movie with VirtualDub
By Drakul in forum EditingReplies: 5Last Post: 19th Sep 2008, 18:08 -
Vegas Movie Studio 7/8 will not open the audio part of mp4/mp3
By budwzr in forum Authoring (DVD)Replies: 3Last Post: 17th Nov 2007, 11:47 -
DVD Author 3 could not open the video part of the file...
By maxy007 in forum Authoring (DVD)Replies: 0Last Post: 10th Aug 2007, 21:05
