    Apr 2012
    Australia
    I have vob2mpg Pro, version 3.2.200 installed on my Windows 7 - 64 bit PC.
    When first installed, the program ran faultlessly. After a period of non-use, I tried to start the program again and received the following message:
    Version: VOB2MPG PRO
    Build: 3.2.2000
    Type: System.ArgumentException
    Source: System.Drawing
    Message: Font 'Arial' does not support style 'Regular'.
    InnerException:
    StackTrace: at System.Drawing.Font.CreateNativeFont()
    at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
    at System.Drawing.Font.Initialize(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
    at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.x85601834555fb7d5()
    at VOB2MPG_PRO.xfed3de3bc2a8e64d..ctor(String[] args)
    at VOB2MPG_PRO.x867eb3246b182488.xc447809891322395(St ring[] xce8d8c7e3c2c2426)
    Chrissyboy said it was a corrupt font and posted an updated or non-corrupt Arial font for Windows XP. Would I be able to use the XP version of this font on my Windows 7 OS?
    Thank you for your help.
    Oct 2005
    666th portal
    the xp font should be fine. right click on the font file and choose install and then yes to overwrite the old one.
    Apr 2012
    Australia
    Thank you aedipuss. That did the job. It is fixed
