Hello sorry, I am a newbie in this forum. I`ve tested mkvmergegui to join my subtitled to the mkv movie file. But the software seem reducing the sound quality. A little bit noisy and dry compared to the source mkv movie file. Correct me if i`m wrong. thanks
Closed Thread
Mkvmergegui can't change any audio quality. It just remuxes and doesn't touch any video or audio. BUt I don't see what that has do with this thread...here are we reconverting with other tools.
Thanks for the info baldrick. I`m using mkvmergegui. with the darkest hour movie, i`ve compared with the source(non subtitled). Ok. If you say that mkvmerge doesn`t change the audio and video quality, i`ve downloaded the darkest hour mkv source file when i played with 40 inch lcd, the movie came with full wide screen. Then i played the muxed darkest hour using mkvmergegui it came 16:9 with black edge on upside and downside. I`m using sony bdp s380 with amp marantz sr5001 with chord company hdmi on video, audioquest coaxial on audio, cav speaker n energy woofer. Anyway if baldrick say that the audio n video doesnt change with mkvmerge gui, i gladly to test another mkv movie n will merge the subtitled. i`ll report soon. For baldrick i look forward for the reply. Thank alot
The film you mention has an aspect ratio of 2.35:1 so on a 16:9 LCD/Plasma etc should have black bars top and bottom.
changing audio format
By spmint in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2012, 17:21 -
Adding softsub with mkvmergeGUI for mpclassic
By douberman in forum SubtitleReplies: 2Last Post: 28th Jul 2011, 00:37 -
Adding soft subs with mkvmergeGUI for mpclassic
By chibaking in forum SubtitleReplies: 13Last Post: 29th Jun 2011, 14:46 -
Cannot Format Specific Options in MKVmergeGUI
By PikachuCLS in forum EditingReplies: 2Last Post: 14th Apr 2011, 16:41 -
MkvMergeGUI and chapters
By Slartibartfast in forum EditingReplies: 2Last Post: 24th Aug 2010, 12:06
