I am trying to split an .mpeg and burn it as a VCD using EZCD. I did a test and set it up with the unsplit file and it works fine. It is just to big for one CD. I split the .mpeg in to two (almost) equal sizes using TMPGenc and now EZCD tells me each of the two new files is not VCD compliant and will not play on a VCD player. I tried to ignore the message and burn anyhow only to have my PC lock up. I tried again with NERO and had the same problem with the split files. Any ideas?
I had that problem myself for a while ago..
But i did this and it works fine..
When u use tmpgenc's mpegtools i assume u use merge&cut.
There´s a little option-window in the main window called : Type
It¨s default is MPEG-1 System (automatic), but this doesn´t allway work so set it to: MPEG-1 Video-CD..
Hope this works 4U to..
Good lucll..
8)
Problem splitting mkv files
By Sennaista in forum Video ConversionReplies: 8Last Post: 5th Jul 2012, 22:57 -
Movica splitting problem
By bartman99 in forum EditingReplies: 0Last Post: 11th Jul 2010, 22:33 -
Splitting Track Problem in Vegas
By duderdude2 in forum EditingReplies: 2Last Post: 23rd Feb 2010, 16:55 -
splitting movies problem
By scarlac in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2009, 03:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18
