I downloaded a few files that had a .Webm extention and cannot play it without the video being awful. By that I mean the audio is fine but the video is only freeze frames every 5-10 seconds or so of what the video actually is.
My main video software I use is MPC-HC 64-bit, along with FFDshow .I also use VLC media player for the files that I can't seem to play correctly. Same issues with the video occured in VLC as well.
If anyone can shed any light on how I can get these awful files to play correctly if possible, what I have to download if anything I would greatly appreciate it.
Version of MPC - MPC-HC 1.6.2.4437 64-bit (latest)
Version of ffdshow - ffdshow_rev4382_20120312_clsid_x64
VLC Version - VLC media player 2.0.1 Twoflower
Results 1 to 10 of 10
Maybe the videos are corrupted? Or maybe problem with your download?
How do you know the video is supposed to play "properly"? -
Well they are videos from a youtube channel that all other videos that arent webm are fine.
I even read the comments and no one said anything about it not playing correctly. It even plays that way in my browser too...
youtube video link - http://www.youtube.com/watch?v=40D7HofaZog -
You probably have an incompatibility between your DirectShow Webm reader/splitter filter and the codecs. You can try using LAV filters instead of Google's reader/splitter. Or vice versa.
https://www.videohelp.com/tools/LAV-Filters -
Sorry if I wasn't specific enough, it even plays with the same problems in my browser too... I just asked a friend of mine to try to view it in his browser/players and he said it played perfect for him in everything except mpc-hc...
I use CoreAVC and CoreAAC . Isn't the LAV filters similar to the CoreAVC? Where do I get these particular 64-bit LAV filters? -
Maybe a DXVA problem. Try Windows GDI ouput in VLC. I have no problem playing the Webm video that was linked to. I used FireFox, WMP 12, MPCHC 64, VLC, KMPlyer and PotPlayer. I have LAV filters installed as the Webm reader/splitter.
@jagabo boom. that fixed it man. I installed the LAV filters and set it to play vp8 and webm stuff for now on. What do you think the problem was and what should I remove/do to make sure I don't run into any more problems?
I don't know exactly what the problem is. I would just stick with LAV filters until other reader/splitter filters get fixed. You might also want to update VLC if you don't have a recent build. I'm running version 2.0.1.
AVIAddXSubs advice needed
By betalb2008 in forum SubtitleReplies: 4Last Post: 25th Jul 2009, 19:55 -
TSmuxer Advice needed
By zenzen1 in forum Blu-ray RippingReplies: 2Last Post: 10th Nov 2008, 08:12 -
iphone advice needed
By rhegedus in forum Off topicReplies: 6Last Post: 30th Aug 2008, 01:38 -
Software advice needed
By ccm in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 12:01 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
