I've been trying to re-order the default settings for the audio streams of a .mkv video and after muxing with mkvmerge I end up with the video being about 30 minutes short.
Any help would be appreciated,
Perhaps source was VFR and you forgot timecodes?
If you only want to change default track, use mkvpropedit , or a gui for it jmkvpropedit
http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvpropedit.html
http://forum.doom9.org/showthread.php?t=163753 -
poisondeathray:
Many thanks for the solution you suggested. I used mkvpropedit and it did the trick.
Cheers,
Torky
Muxing with mkvmerge
By sharu006 in forum Video ConversionReplies: 7Last Post: 14th Dec 2012, 12:48 -
Batch subtitle muxing - mkvmerge
By mkr10001 in forum EditingReplies: 1Last Post: 18th Feb 2012, 13:03 -
Correct way of muxing subtitles with mkvmerge
By zammil in forum SubtitleReplies: 3Last Post: 4th Jan 2011, 05:29 -
MKV Muxing / MKVmerge GUI 4.4.0 / The KMplayer 2.9.4.1435
By stanfield in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 05:36 -
Muxing MKV file with mmg (mkvmerge)
By HAL4711 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 19:49
