Which GPU is better for encoding/decoding/transcoding? I dont have to play games so my only concern is the multimedia handling only.
I can't tell you which of those is better but if you have a quad core or better CPU you can probably get both faster and better results encoding with x264 with the veryfast or ultrafast presets.
GPU encoding comparison: http://www.behardware.com/articles/828-1/h-264-encoding-cpu-vs-gpu-nvidia-cuda-amd-str...-and-x264.html -
Most people who try to squeeze extra power out of their GPU have under powered systems. This issue is really best fixed by investing in a more powerful CPU with more cores than to try to fix it on the cheap via a GPU. If you try the cheap fix via a GPU, I will warn you that there is some chance that you will eventually feel like you wasted your money trying to attack the problem that way.
does core i series (ivy bridge) 3rd generation have any improvements in intel quick sync instructions over sandy bridge (2nd generation) ?
The Ivy Bridge GPU definitely has faster QS performance. Slightly improved quality too.
http://www.tomshardware.com/reviews/ivy-bridge-benchmark-core-i7-3770k,3181-7.html
http://www.anandtech.com/show/5771/the-intel-ivy-bridge-core-i7-3770k-review/21#
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
judge erases 525 grand debt to punish bank
By deadrats in forum Off topicReplies: 3Last Post: 26th Nov 2009, 18:22 -
Very old Pioneer DV-525... surprisingly tolerant!
By kschang in forum DVD & Blu-ray PlayersReplies: 8Last Post: 17th May 2008, 17:03 -
NTSC Playback on PAL TV. Only 525 lines being displayed.
By mr_mop in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Sep 2007, 09:06 -
525-Line Widescreen Pixel Aspect Fraction
By Acid_Reign in forum Newbie / General discussionsReplies: 5Last Post: 4th Jun 2007, 17:15
