Hi everyone! I have searched everywhere about a way to make anime's lineart more darker, without change brightness in the all video. For example:
http://imageshack.us/photo/my-images/812/finalmix.png/
I want to make "black" lines of the raw (on left) such as black lines of right video.
How can I make that?
Do you know how to use avisynth?
http://avisynth.org/mediawiki/Main_Page#New_to_AviSynth_-_start_here
You type in your source filter, then the filter and it's settings
Look at the documentation for the settings
http://www.aquilinestudios.org/avsfilters/sharpeners.html#fld
e.g
Code:AVISource("video.avi") FastLineDarken() -
Ok, I find the avs script about this plugin. But now I don't know if it is possible to insert it into megui. I try it but it was failed! For that reason I want to know which program should I use to instert fastlinedarken, and if it's possible to use it with megui. Thanks again for the reply dude!
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
can you help me how to burn a 8 episode anime video to a 4.7gb size DVD?
By komiya in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2008, 04:15 -
Guidance needed to encode an anime video to HD quality
By cybertron91 in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2008, 23:02 -
Creating dvd video with 20+ episodes of anime
By kurt_tml in forum Authoring (DVD)Replies: 9Last Post: 21st Jul 2008, 19:26 -
Is there anything i can do about the bad pixels in these anime video files?
By f-zer0 in forum Video ConversionReplies: 9Last Post: 9th Feb 2008, 01:24
