what i want to to is capture text from a website (such as movie info, biography's, or a 10 chapter story, ect) burn onto a cd or dvd add be able to read it like a book on my dvd player
so 2 questions-
1. how do i download and save the text to my hdd?
2.how do i convert and burn the text and make it playable using the forward and back arrow keys?
This is a big ask. There is no direct method of simply displaying a text file on a DVD player. The methods involved in building a DVD capable of displaying static screens, as a book, with forward/back buttons would fill a book.
DVD slideshow GUI can do it (with a lot of work).
You will have to copy web page text then paste it as an text overlay onto an image template you have created, then export it as a slide (as jpg, png or bmp). To do this you will need a graphics program which will handle text (OpenOffice 'Draw' will do). Download DVD Slideshow GUI program, go to the help section and see entry 'Export to DVD Menus'. In order to achieve your ask you will need to master this program AND this: GUI for dvdauthor.
Like I said, no easy task.
A simpler method, since most DVD players have the ability to generate their own slideshows from a folder of images, is to make a master template, create slides with text in an image editor, export them to a folder and burn it on/as a data CD/DVD.
Make sure you export your slides in a format compatible with your DVD player (usually JPG, PNG and BMP).
Just start the slideshow and use the pause, zoom and scroll keys to view the image(s).
Forward and back keys should let you step through the images in the folder.
You could also just screen capture areas of the web pages and use these as your slideshow images.
I am not aware of any single program which can do what you require.Last edited by transporterfan; 21st Apr 2012 at 08:35.
Two .srt files: can I transplant the times on one to the text on the other?
By cinesimon in forum SubtitleReplies: 4Last Post: 21st Oct 2011, 07:26 -
Xvid4PSP Recording Error Text files only ?
By PowerFalcon in forum Video ConversionReplies: 3Last Post: 23rd Aug 2011, 21:41 -
Joining Subtitle Text Files.
By wasimismail in forum SubtitleReplies: 3Last Post: 10th Jul 2009, 16:21 -
Capture Closed Captioning and send to a text file
By videohelpkg in forum Capturing and VCRReplies: 0Last Post: 21st Jan 2009, 21:03 -
What is the best way to insert text into VOB files?
By SUPERIOR in forum EditingReplies: 2Last Post: 15th May 2008, 03:34
