    Apr 2012
    singapore
    I have a bunch of flv files and these are somewhat difference from the flv files that i used to see on the web.When i checked the video file with mediainfo ,it show that the video is avc and the audio is aac.I tried to join them together with avidemux but it is not working.I have to change the main audio file into mp3 and raplace it within the avidemux and then have to save it as avi to make it works.Isn't there any simple joiner to join this kind of video coding without changing format?.Any help would be appreciated.This is the video format.
    Format : Flash Video File size : 225 MiB Duration : 1h 2mn Overall bit rate : 500 Kbps Tagging application : Yet Another Metadata Injector for FLV - Version 1.8
    Video Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L2.1 Format settings, CABAC : No Format settings, ReFrames : 1 frame Muxing mode : Container profile=Unknown@2.1 Duration : 1h 2mn Bit rate : 386 Kbps Nominal bit rate : 400 Kbps Width : 432 pixels Height : 240 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 24.000 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.155 Stream size : 179 MiB (79%) Writing library : x264 core 120 r2120 0c7dab9 Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x131 / me=hex / subme=5 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=50 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=400 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=400 / vbv_bufsize=200 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Duration : 1h 2mn Bit rate : 94.3 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Stream size : 45.2 MiB (20%)
