Not really sure how this could have happened. Lossless is lossless. Plus eac3to supposedly has some built-in clipping prevention measures. Despite this, the center channel has been badly clipped. I mean it is harsh. Without question, the audio did not start out that way.
I may have to try the DTS core or the AC3 channel. But certainly I'd like some advice. Either for somebody to tell me I'm doing it wrong, or maybe an extra command that will ensure the result isn't clipped. Here's my very basic command line:
eac3to input_dts-hd_ma.dts output_wav.w64
I used Audacity 2.0 to investigate the audio.
Probably you will have to try different versions of ArcSoft's "DTSdecoderDll.dll", none of which is flawless BTW
http://forum.doom9.org/showthread.php?p=1508578#post1508578
Besides, none of the 5 versions that were tested can decode stereo DTS-MA losslessly
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 11:35 -
eac3to with HdBr Stream Extractor Decoding DTS-HDMA?
By MACCA350 in forum Blu-ray RippingReplies: 8Last Post: 17th Aug 2011, 01:01 -
2 Channel AC3 25fps to 24fps eac3to problem
By Pegbeard in forum AudioReplies: 23Last Post: 13th Apr 2010, 20:41 -
SpiderMan3 BD Backup - No Center Channel on PS3...
By mshilly in forum Blu-ray RippingReplies: 6Last Post: 18th Jan 2009, 02:49 -
eac3to conversion- thd->dts
By runLoganrun in forum AudioReplies: 0Last Post: 16th Dec 2008, 13:47
