Results 1 to 30 of 60
  1. Hi,
    At the moment I'm using iMKVExtract to extraxt srt from a mkv file.
    Which is a very slow process since I have multiple mkv files.
    Is there a way to extract srt from several mkv files?
    It would also be nice if the srt's automatically get the same name as the mkv.
    So if you know a way to do this, I would really appreciate it.
    It may be a GUI or with a script.
    (If I'm not mistaken there is a tool like this for windows and it's called mkvcleaver but haven't found anything for mac)
    Greets and thanks in advance.
    Gosa
  2. wrote a small tool that allows to extract (all) video and/or audio and/or subtitle stream from mkv files.
    1. start tool
    2. drag&drop the mkv's in the empty list (you can also drop folders)
    3. set output folder
    4. start extraction
    5. wait till it's finished
    it's not tested a lot but, judging from my tests it's doing what it's ment to do,..
    Cu Selur
  3. Hi,
    Thanks for the reply!
    I tried it but nothing seems to happen.
    But I might be missing something simple.
    What I did was unzipping the file.
    I dragged the app into my programs and I ran the program.
    Then I followed the steps so I dragged the mkv-files, then I set the output folder.
    I wanted to select Subtitle Stream but it didn't allow me to select the sub alone.
    I got the following message: You need to select at least one type of stream to extract.
    So I selected the audio and video as well and then it started.
    Then it went very fast so I had a feeling that it wasn't really extracting.
    When I went to the output folder, nothing was there.
    Do I need to do something else? Or does your app work with another app? Maybe I need to install something extra?
    I have a mac osx lion 10.7.3 by the way.
    Cheers
  4. I wanted to select Subtitle Stream but it didn't allow me to select the sub alone.
    -> fixed (I accidentally checked the audioCheckBox instead of the subtitleCheckBox)
    hmm,.. worked fine here,.. (mkvmerge and mkvextract 5.5 are included,..)
    -> give a few minutes, I'll add some additional status info, so bugs are easier to track,..
  5. Thanks for your time.
    I'm looking forward to it.
    Cheers
  6. Okay, I figured out where the main problem is. The mkvmerge/mkvextract versions I added to the package and that are available on the mkvtoolnix homepage are not statically compiled and do not come with all the required libraries they need.
    -> I'll probably compile mkvmerge&co myself then
  7. Attached a version that looks for mkvmerge&mkvextract inside /opt/local/bin which is where MacPorts installs them.
    I'll later look into compiling mkvmerge&mkvextract statically, so that MacPorts isn't needed.
  8. Think I got it know,.. and I finally start to understand the .app structure better,..
  9. Hi,
    Does this version need mkvextract and mkvmerge installed in /opt/local/bin or does it work statically?
    I tried the new zip and after running it I get the following:
    p, li { white-space: pre-wrap; } setting output folder to /Users/SG/Movies/new,..
    starting extraction,...
    file: /Users/SG/Movies/test.mkv, audio: 1, video: 1, subtitle: 1, output: /Users/SG/Movies/new
    starting: "/Applications/MkvExtractor 3.app/Contents/MacOS/mkvmerge" -I "/Users/SG/Movies/test.mkv"
    analyzing output of analyzer,...
    video - id: 0, type: V_MPEG4/ISO/AVC
    audio - id: 1, type: A_AAC
    subtitle - id: 2, type: S_TEXT/ASS
    extracting content for /Users/SG/Movies/test.mkv
    starting: "/Applications/MkvExtractor 3.app/Contents/MacOS/mkvextract" tracks "/Users/SG/Movies/test.mkv" --ui-language en_US --raw 1:"/Users/SG/Movies/new/test_1.264" 2:"/Users/SG/Movies/new/test_2.aac" 3:"/Users/SG/Movies/new/test_3.ass"
    finished extraction for /Users/SG/Movies/test.mkv
    input queue is finished,...
    Thanks for trying to help.
  10. mkvextract&mkvmerge are included (but dynamically linked)
    output looks okay.
    -> did you check if '/Users/SG/Movies/new/' contains the extracted files?
    (btw. it should also work if you just enable the subtitle extraction)
    atm. there's a lot of unneeded stuff in the log, but I think I leave it there for a while until I'm sure everthing is working,..
  11. Hi,
    Sadly there is nothing in the /Users/SG/Movies/new/
    I think it's because I don't have mkvmerge and mkvextract installed.
    So i need to do that first.
    I installed macports and I tried "sudo port install mkvtoolnix" but I get
    Warning: xcodebuild exists but failed to execute
    Warning: Xcode does not appear to be installed; most ports will likely fail to build.
    So apparently I need to install Xcode first.
    I will try and install Xcode.
  12. it would help if you call:
    in a terminal an post what the output is.
    Installing mkvmerge,mkvextract,... will not fix the problem,... since MkvExtractor will only look inside the .add folder
  13. Hi,
    This is what I excuted:
    MBPSG:opt SG$ "/Applications/MkvExtractor 3.app/Contents/MacOS/mkvextract" tracks  "/Users/SG/Movies/test.mkv" --ui-language en_US --raw  1:"/Users/SG/Movies/new/test_1.264" 2:"/Users/SG/Movies/new/test_2.aac"  3:"/Users/SG/Movies/new/test_3.ass"
    This is what I got:
    dyld: Library not loaded: /opt/local/lib/libmagic.1.dylib
      Referenced from: /Applications/MkvExtractor 3.app/Contents/MacOS/mkvextract
      Reason: image not found
    Trace/BPT trap: 5
    No Idea what that means.
  14. That means there is this one or more libaries missing in the package,... -> I'll look on my system
  15. Attached a version with libmagic.1.dylib included. -> try the command line with this version
  16. Hi,
    I tried with the new zip and I still got:
      Referenced from: /Applications/MkvExtractor.app/Contents/MacOS/mkvextract
    Trace/BPT trap: 5
    Are you sure you zipped the latest version
  17. that's strange because it is included in the package (MkvExtractor.app/Contents/Frameworks/libmagic.1.dylib) thought that would fix the problem,..
  18. Hi,
    I went to the directory with Terminal and it's indeed in the Framework directory.
    I tried to copy to the lib directory but there is some kind of permision problem:
    MBPSG:Frameworks SG$ cp libmagic.1.dylib /opt/local/lib/libmagic.1.dylib
    cp: /opt/local/lib/libmagic.1.dylib: Permission denied
  19. Aha.
    I used
    sudo cp ...
    And now I get the following:
    dyld: Library not loaded: /opt/local/lib/libvorbis.0.dylib
    Trace/BPT trap: 5
    So I will do the same and let you know how it went.
  20. grrr,.. that one like libmagic isn't included in the official mkvtoolnix downloads,.. :/
  21. Hi,
    Well I copied the magic file but like I posted I need
    libvorbis.0.dylib
    Have no idea where to get that. I thought I would maybe find it in the frameworks directory but it wasn't there.
    Do you know where I can get it?
  22. 1. let me look, I thing I got it somewhere on my mac
    2. I will contact Jonathan who makes the mkvtoolnix mac packages.
  23. Great,
    I will patiently wait
    Thanks for sticking arround and helping out.
    i'm so looking forward to be able to extract multiple subtitles at once
    It's gonna save me a lot of time.
  24. attached libvorbis.0.dylib, post if you need other libs,..
    Hoping Jonathan will include all the binaries in the official build, than I could add the offical .app into my .app
  25. Hi,
    I'm still missing library files.
    dyld: Library not loaded: /opt/local/lib/libogg.0.dylib
    Trace/BPT trap: 5
    Is there a library pack that I need to download so I have most common dylib files.
    My mac is only 2 old and I"m still a bit new to mac so...
  26. personally I installed MacPorts and install most of the small tools through it,... attached libogg
  27. Hi,
    I didn't want to annoy you but I can't find liblzo2.2.dylib
    If you happen to know which dylib mkvmerge and mkvextract use, feel free to zip them up.
    It will spare some time sending each dylib
    For now I have only three files:
    ls /opt/local/lib
    libmagic.1.dylib    libogg.0.dylib        libvorbis.0.dylib
  28. belief me if I would now which libraries are needed I would already have made a complete zip package,..
    (btw. you are not annoying, this way I too learn which libraries mkvtoolnix needs )
    liblzo2.2.dylib attached
  29. You're definitly the most patient person I know on any forum I've ever been, lol.
    This time it asks for another dylib but with another reason:
    dyld: Library not loaded: /opt/local/lib/libiconv.2.dylib
      Reason: Incompatible library version: mkvextract requires version 8.0.0 or later, but libiconv.2.dylib provides version 7.0.0
    Trace/BPT trap: 5
    Could you send your version please? thnx
  30. attached libiconv.2.dylib
    at least now I know why there are not so many small encoding guis&co for mac out there,.. it's a pain to deploy them unless mac a macport,..
