  1. Hi,
    I convert some ISO to MKV files by using hand brake. Then I installed CCCP to make the MKV files available in WMP running on Windows 7 x64.
    I configured WMP for streaming.
    And tried to look at them on my blue ray (WIFI).
    At start everything seems to be good but after jumping from chapter to chapters, I found the sync was horrible.
    As I am a newbie, I would like to know what is the way I should follow to solve my problem.
    THe DVD's are Zone 1 Pal and I am running on NTSC Zone 2. Would it be important to change the FPS auto to another value?
    Thanks,
    François
  2. Hi Francois,
    Can you watch your ISO direct using VLC; therefore No need for conversion!
    G!
  3. Hi,
    I am using WMP to broadcast the Episodes on my TV using DLNA. My TV just read MKV, DivX and avi.
    Thanks,
    François
  4. Hi Francois,
    I don't have any setup like yours ... but I want to Help you, since folks at VH are always here to Help everyone including lil ol me!
    Francois, here are 4 links I found and I think the first two might have your answer ... so, check them out and POST back your result for the next person ...
    Stream computer desktop to TV using DLNA, TVersity and VLC
    Serve Up Your Video Files to Your DLNA-Compliant TV
    VLC and DNLA
    DLNA server - without PS3???
    G!
