Hi all.
I re-installed Windows 7 64-bit (had 32-bit before) and installed mpc-hc 64-bit and any mkv file I try to play with mpc-hc is just playing badly.
Video is slow and glitchy, audio isn't synced and so on...
I have a GeForce 8600GT video card and latest drivers installed.
Before re-installing windows those video files played perfectly.
I tried using mpc-hc 32-bit but same result.
I'm using mpc-hc without any special configurations.
I tried playing with the checkboxes of the internal filters (matroska and dxva) but same result.
I don't really remember but maybe before formatting I had matroska (haali) splitter and ffdshow installed and used, but i'm not sure.
I installed them both and disabled this checkboxes in preferences of mpc-hc but still playback isn't excellent as was before.
Screenshot: http://imageshack.us/photo/my-images/444/42768198.jpg/
I know mpc-hc is using haali and ffdshow as I see their icons in taskbar but still video is slow and not so good.
MediaInfo of an mkv file i'm trying to play: http://pastebin.com/qmahkyWx
Please help!
Thanks![]()
Results 1 to 18 of 18
Have you tried changing the DirectShow output device? The problem could be a graphics driver bug.
Your source video has a mod2 frame height. That can cause problems with some decoders. Do other videos have the same problems?
I have the same video card and i've got the same problem like you. In my case, the video card driver was the cause. Try removing all software and drivers belonging to your video card and re-install them (after this, the latest version seems to be ok, at least for me: download it from here ).
I have a new info that maybe help us solve it.
The video is glitchy and slow only when subtitles are ON.
If I choose an output that doesn't deal with subtitles, the video is perfect.
If I stay on the default settings everywhere, but turn subtitles off (right click on video and untick "enabled" from subtitles) the video is perfect too!
What is causing the subtitles to mess with the video?
Thanks for all the help and hope a solution will be found soon
Which version of ffdshow are you using? Have you tried installing vsfilter? I'm not sure how well ffdshow's subtitle handling works.
You might try installing the 32-bit versions of ffdshow and vsfilter, and using the 32-bit version of MPCHC (they'll coexist with the 64-bit versions, as far as I've seen - that's the way I have them set up on my Vista64 tower), and see if the 32-bit version handles everything at all better or differently.
Also, as you're using Win7, have you tried using Win7DSFilterTweaker to make sure everything's the way you want it with the DirectShow filters? (May be something you should be careful about using, though, I don't know. I'm not using Win7.
If cameras add ten pounds, why would people want to eat them? -
There was a post recently that was similar. Apparently subtitles caused these glitches when DXVA was used,
but worked fine otherwise (when using software decoding). -
I try to deal with the problem without using haali and ffdshow, as the problem is not with the video handling but with subtitles handling..
When I said subtitles are causing this I meant I'm using all the default internal filters of mpc-hc. Is there a way to solve it within mpc-hc as it should?
For now ffdshow and haali are irrelevant.
Reinstalling Windows XP
By wulf109 in forum ComputerReplies: 17Last Post: 2nd Apr 2012, 19:52 -
MPC-HC, MKV and memory problem
By Docoptik in forum Software PlayingReplies: 7Last Post: 18th Mar 2012, 22:40 -
No audio in MKV files when using MPC.
By ohnoeee in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2011, 04:04 -
Reinstalling windows vista
By Sportster Freak in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2009, 23:23 -
Playing 24p MKV files with MPC, haali and ffdshow.
By Phorze in forum Media Center PC / MediaCentersReplies: 5Last Post: 13th Aug 2007, 18:41
