    Mar 2012
    bc canada
    Hi and thanks so far for all the help,my question is this is download a.movie,put it through the video converter, then load it to my PlayBook,when I then go to play it from the bb PlayBook to my tv,most movies don't come close to filling up the tv screen, hope I've explained this properly
  2. Member Cornucopia's Avatar
    What movie (specs please - use mediainfo)?
    What converter (software & settings)?
    What Plabook Android mediaplayer app & settings are being used?
    More info necessary...
    Mar 2012
    bc canada
    hey scott I have the free make video converter,my tablet is blackberry playbook so its not an android,as far as settings go on the converter I didnt realize there was some that I could adjust??
  4. Many movies are wider than 16:9 (2.35:1 is common) and shouldn't fill a 16:9 screen. The Playbook's screen is about 1.7:1 so even a 16:9 (1.78:1) video shouldn't fill the screen.
  5. Member Cornucopia's Avatar
    Well, we're both kind of right - BBPlaybook OS is an Android-alike OS (built by RIM). IOW, it uses Linux as it's kernal, just like Android does. It even has an Android runtime (similar to Wine-for-Linux that allows Windows apps to run on Linux), so many Android apps will run unchanged on it.
    That's what I was talking about. So, to repeat and revise my earlier question: Are you using the STOCK video player app to show the video, or are you using one of the MANY Android video player apps (like MoboPlayer) to show the video? What are it's settings?...
    Yes, there should be some settings you can adjust. I'd look under the [Edit] or [Convert] menu items (don't use FMVC myself)...Likely you can create your own new "custom" presets.
    But this brings up another point. Since you're using FMVC, you must have some additional steps involved in getting it to the PC and then to the BB Tablet that you didn't mention. Please describe those steps as well?
