Results 1 to 11 of 11
    Oct 2003
    Canada
    I have just got a new system with Windows 7
    I downloaded the latest ImgBurn, but I can only load one file into and it won't load anymore.
    The first file just sits there and I can't get off that screen.
    The back button is greyed out.
    I have uninstalled and rebooted a few times with no luck
  2. Banned
    Freedonia
    If you did not get it from http://www.imgburn.com then there is a possibility that you got a fake ImgBurn that may be a virus. The behavior you are seeing is definitely not normal.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    They've got a pretty good forum with informative people. Maybe try there.
    http://forum.imgburn.com/index.php?
    jman's right and they tell you onsite...if imgburn doesn't run right, probably a virus
    Oct 2003
    Canada
    I got it from the ImgBurn site. But maybe I picked up a virus somehwere else?
    Oct 2003
    Canada
    Well lI downloaded the file from ImgBurn site again. Did full virus scan, no viruses popped up.
    I still can't load more than one file.
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just curious have you been trying the same file over and over again? Could the file itself be corrupt? Can you put other files in?
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What mode do you have selected in Imgburn? Build mode? (Or, what are you picking from the "EZ-Picker" (if I remember that correctly) wizard screen?)
    Oct 2003
    Canada
    I managed to burn 3 files singularly with Img Burn. They play fine. I tried to load some older files that worked fine before. Same problem
    Oct 2003
    Canada
    I'm using build. Same as I always used
  10. Member Cornucopia's Avatar
    Yeah, if you are in Write mode, it is only supposed to have 1 input file - the disc image. And then you burn it...
    Edit: works for me. Virus or PIBCAK.
    Oct 2003
    Canada
    Just loaded the ImgBurn fle into my Acer laptop Windows XP. Everything fine. Something I'm doing wrong with Windows 7. I load one file, and I can't get back to the folder where the other DivX files are
