Strange. But when I hit start to start the encode it only takes around 1 sec!!
Results 61 to 73 of 73
Okay, that's a totally new one, I never had that!- Audio isn't MPEG-2/4 AAC with ADTS
Error importing /var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x03 - Square Wheels DELAY -43ms__aid_1__16_37_08_771_02.aac#audio: BitStream Not Compliant
Seems like the output ffmpeg produces is not aac, call looks fine,..
-> WTF!?!Code:"/Applications/Hybrid.app/Contents/MacOS/ffmpeg" -threads 4 -y -i "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x03 - Square Wheels DELAY -43ms__aid_1__16_37_08_771_01.mp3" -ab 128000 -ac 2 -ar 48000 "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x03 - Square Wheels DELAY -43ms__aid_1__16_37_08_771_02.aac"
Going to do some tests,.. I'll report back in a short while.
didn't know aac was still considered experimental in ffmpegCode:[NULL @ 0x10184a600] Codec is experimental but experimental codecs are not enabled, see -strict -2
(I did know it wasn't the best aac encoder but this,..)
-> have to check a few things,.. and probably start building ffmpeg myself,.. :/
seems like (only on mac) you have to add: '-strict experimental' to the command line to use the ffmpeg aac encoder,.. (going to upload a new version of Hybrid which does that,..)
Cu SelurLast edited by Selur; 6th May 2012 at 15:49.
btw. if a mod/admin reads this: would be a nice feature if the upload function of the forum could show some sort of progress indication,...
(or play a tone if it's finished,.. when uploading a rather large file, waiting without any progress indication is really annoying)
Cu Selur
Ps.: will upload the file to my site and send you a link,.. attaching it to this post just failed,.. -
Downloading it right now. Just got home, went out to eat. Going to try it in a few minutes and update you then.
Update: Audio extracted and compiled with no issues. Going to try a full audio and video encode.Last edited by Cabal2000; 6th May 2012 at 17:22.
NICE!Audio extracted and compiled with no issues.
okay, since it 12pm over here, I'll probably go to bed soon. Will check tomorrow morning if everything went fine and I can release a new public version or if I have to go for a bughunt againGoing to try a full audio and video encode.
Hey man it worked great!!!!
One thing that I would like to see changed would be some defaults.
Exp... Iphone, Appletv, Ipad presents. Or if you choose X264 as the video handler then aac is the default audio, if you doing Xvid then mp3 is your default audio handler. Or something like that if you know what I mean. -
I know what you mean, it's on my general to do list for quite some time, problem is I really don't have the time to collect all the data necessary for it.
like what is allowed and what not on which device, so Hybrid can stop the user from using values that are not compatible with his device selection,..
Last time I started and stopped my efforts when there was a lot of talk about x264 getting a '-device' option for a bunch of devices, so doing the work double seemed to be a bad idea at the time.
Cu Selur -
Got ya man!! One thing at a time.
For now I will keep on testing different configurations and see what I get. -
Good to know, will do. Thanks for the info.That's a browser issue.
Use Chrome on Mac -- problem solved.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2378Last Post: 27th Nov 2025, 10:38 -
what hybrid cars should be
By deadrats in forum Off topicReplies: 0Last Post: 2nd Mar 2010, 19:48 -
Hybrid Car ??
By jdawson1960 in forum Off topicReplies: 19Last Post: 21st Nov 2008, 23:02 -
hfs hybrid
By cdenley in forum MacReplies: 4Last Post: 14th Aug 2007, 11:15
