Looks like a nice little program!!
But I am having audio problems or lack there of.
I have a MPEG-4 Xvid Video .avi with standard Mpeg-1 layer 3 176 44.1khz audio.
But for some reason when I encode the file, only been trying mp4, i am not get any audio???
In audio handler I have tried ignore and no audio.
In audio handler I have tried custom then going under the audio tab main leaving everything as default, when I click Add to Queue and then Start Queue nothing happens. Under Jobs tab, i have
-STARTED mplayer processing started
-STARTED extraction audio stream with mplayer.
But are at 0%, i even lift it for an hour to made sure.
I am using your latest complete build on the Hybrid package from your site and downloading the missing avsINFO.pro file.
Any help would be great!!!
Results 31 to 60 of 73
1st you don't need avsInfo at all.
2nd please create a debug output (see: http://www.selur.de/support for what infos might be helpful to reproduce a problem)
Just tried here and it seemed like it's working on my machine,.. it may be mencoder/mplayer is missing some dependency again (thought I compiled it statically) will look at it later today, if you send me some debugoutput and I'm back from a family event,...
If Hybrid doesn't come back from the extraction, you could try to:
1. switch to the Jobs-tab
2. disable 'Minimize job command lines'
3. copy the extraction call
4. call the call in a terminal to determine if something is going wrong,..
for better understanding of Audio handling:
source: toolTip in HybridAudio handling: Allows you to select the general audio handling.
Available options are:
- custom: enables the Audio-tab, where you can manually choose the audio and how it should be processed by adding it to the audio job queue.
- autoadd (first): enables the Audio-tab, but automatically adds the first input audio stream from the input file to the audoi job queue with the settings defined in the Audio-tab.
side notes:
- You can still add additional audio streams in the
- Audio-tab.)
- Setting will not adjust to changes regarding the audio format after loading the source!
- auto add (all): like auto add (fist), but all the stream from the input are processed automatically.
- passthrough all: automatically adds all the streams from the input to the audio queue in the Audio-tab.
- ignore: disables all audio handling (needed if you want to create a video only file)
If you select custom, you need to make sure to add your selection in the audio tab by pressing the '+' button.
Cu SelurLast edited by Selur; 6th May 2012 at 01:44.
Here is the log file.
Tried several different things but still the same thing.
Using Version 10.7.3 of Mac OS X by the way. -
what happens if you call in a terminal:
(only thing strange is the wave header part,... -> will look into it, but sadly a log file doesn't help much. I need the debug output output,..Code:"/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -aid 1 -msglevel statusline=5:all=0 -mc 0 -hardframedrop -vc dummy -nocorrect-pts -aid 1 "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi" -vo null -ao pcm:fast:waveheader:file=""/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3""
Cu Selur -
yup, I think it's the waveheader thing, please check if:
runs fine if you call it in a terminal.Code:"/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -aid 1 -msglevel statusline=5:all=0 -mc 0 -hardframedrop -vc dummy -nocorrect-pts -aid 1 "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi" -vo null -ao pcm:fast:file=""/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3""
It does not do anything for me. Just stays at 0% and nothing. I lift it open for a full hour.
Trying it again right now.
I have it to custom,
-under Audio tab, Reencode audio stream checked on, Bitrate set to 192, then clicked on the + symbol
-Last edited by Cabal2000; 6th May 2012 at 10:22.
try:
Cu SelurCode:"/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -v -mc 0 -vc dummy -nocorrect-pts -aid 1 -i "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi" -dumpaudio -dumpfile "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3"
In a Terminal? I did but nothing happened. Sorry but I am still very new to MAC
yes in a terminal.
Nothing, is not much,...
You need to:
1. open terminal copy&paste the line above
2. press the enter-key
this should execute the command line and at least cause some sort of output,..
Cu Selur -
Last login: Sun May 6 11:56:18 on ttys000
boxee:~ ianedwards$ "/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -v -mc 0 -vc dummy -nocorrect-pts -aid 1 -i "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi" -dumpaudio -dumpfile "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3"
Unknown option on the command line: -i
Error parsing option on the command line: -i
MPlayer UNKNOWN-4.2.1 (C) 2000-2012 MPlayer Team
CPU vendor name: GenuineIntel max cpuid level: 13
CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (Family: 6, Model: 42, Stepping: 7)
extended cpuid-level: 8
extended cache-info: 16801856
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNowExt: 0 SSE: 1 SSE2: 1 SSSE3: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 SSSE3 CMOV
get_path('codecs.conf') -> '/Users/ianedwards/.mplayer/codecs.conf'
Reading optional codecs config file /Users/ianedwards/.mplayer/codecs.conf: No such file or directory
Reading optional codecs config file /Users/selur/Desktop/target/bin-tools/target/etc/mplayer/codecs.conf: No such file or directory
Using built-in default codecs.conf.
init_freetype
Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
get_path('fonts') -> '/Users/ianedwards/.mplayer/fonts' -
okay, please try:
Code:"/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -v -mc 0 -vc dummy -nocorrect-pts -aid 1 -dumpaudio -dumpfile "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3" "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi"
Last login: Sun May 6 12:07:09 on ttys000
boxee:~ ianedwards$ "/Users/ianedwards/Desktop/Hybrid.app/Contents/MacOS/mplayer" -v -mc 0 -vc dummy -nocorrect-pts -aid 1 -dumpaudio -dumpfile "/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3" "/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi"
init_freetype
Configuration: --cc=/usr/bin/gcc --disable-x11 --disable-gl --disable-qtx --with-freetype-config=/Users/selur/Desktop/target/bin-tools/target/bin/freetype-config --prefix=/Users/selur/Desktop/target/bin-tools/target
CommandLine: '-v' '-mc' '0' '-vc' 'dummy' '-nocorrect-pts' '-aid' '1' '-dumpaudio' '-dumpfile' '/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3' '/Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi'
Using Darwin accurate timing
Terminal type `xterm-256color' is not defined.
get_path('input.conf') -> '/Users/ianedwards/.mplayer/input.conf'
Reading optional input config file /Users/ianedwards/.mplayer/input.conf: No such file or directory
Reading optional input config file /Users/selur/Desktop/target/bin-tools/target/etc/mplayer/input.conf: No such file or directory
Falling back on default (hardcoded) input config
Can't init Apple Remote.
get_path('MythBusters - 10x05 - Battle Of The Sexes.avi.conf') -> '/Users/ianedwards/.mplayer/MythBusters - 10x05 - Battle Of The Sexes.avi.conf'
Playing /Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi.
get_path('sub/') -> '/Users/ianedwards/.mplayer/sub/'
[file] File size is 397235488 bytes
STREAM: [file] /Volumes/Torrent Drive/1.Torrents/2.TV Shows/MythBusters/MythBusters - 10x05 - Battle Of The Sexes.avi
STREAM: Description: File
STREAM: Author: Albeu
STREAM: Comment: based on the code from ??? (probably Arpi)
libavformat version 54.3.100 (internal)
Configuration: --enable-gpl --enable-version3 --enable-nonfree --disable-doc --disable-debug --enable-libmp3lame --enable-libx264 --enable-libxvid --enable-libfreetype --cc=/usr/bin/gcc --disable-vda --disable-devices --disable-ffplay --disable-ffserver --disable-ffprobe --disable-shared --enable-static --prefix=/Users/selur/Desktop/target/bin-tools/target
LAVF_check: AVI format
AVI file format detected.
list_end=0x192
======= AVI Header =======
us/frame: 40000 (fps=25.000)
max bytes/sec: 0
padding: 0
MainAVIHeader.dwFlags: (2320) HAS_INDEX IS_INTERLEAVED TRUST_CKTYPE
frames total: 64049 initial: 0
streams: 2
Suggested BufferSize: 0
Size: 640 x 352
list_end=0x120
==> Found video stream: 0
[aviheader] Video stream found, -vid 0
====== STREAM Header =====
Type: vids FCC: XVID (44495658)
Flags: 0
Priority: 0 Language: 0
InitialFrames: 0
Rate: 25/1 = 25.000
Start: 0 Len: 64049
Suggested BufferSize: 133875
Quality 0
Sample size: 0
Found 'bih', 40 bytes of 40
======= VIDEO Format ======
biSize 40
biWidth 640
biHeight 352
biPlanes 1
biBitCount 12
biCompression 1145656920='XVID'
biSizeImage 337920
Regenerating keyframe table for MPEG-4 video.
======= Video Properties Header =======
Format: 0 VideoStandard: 0
VRefresh: 25 HTotal: 640 VTotal: 352
FrameAspect: 16384:9011 Framewidth: 640 Frameheight: 352
Fields: 1
== Field 0 description ==
CompressedBMHeight: 352 CompressedBMWidth: 640
ValidBMHeight: 352 ValidBMWidth: 640
ValidBMXOffset: 0 ValidBMYOffset: 0
VideoXOffsetInT: 0 VideoYValidStartLine: 0
list_end=0x192
==> Found audio stream: 1
[aviheader] Audio stream found, -aid 1
Type: auds FCC: U (55)
Flags: 0
InitialFrames: 0
Rate: 16000/1 = 16000.000
Start: 0 Len: 40937012
Suggested BufferSize: 418
Quality 0
Sample size: 1
Found 'wf', 30 bytes of 18
======= WAVE Format =======
Format Tag: 85 (0x55)
Channels: 2
Samplerate: 44100
avg byte/sec: 16000
Block align: 1
bits/sample: 0
cbSize: 12
mp3.wID=1
mp3.fdwFlags=0x2
mp3.nBlockSize=418
mp3.nFramesPerBlock=1
mp3.nCodecDelay=0
list_end=0x1CC
hdr=Software size=37
Software : MEncoder Sherpya-MT-SVN-r32848-4.5.0
list_end=0x1785C878
Found movie at 0x100C - 0x1785C878
Reading INDEX block, 161994 chunks for 64049 frames (fpos=394643584).
AVI index offset: 0x1008 (movi=0x100C idx0=0x4 idx1=0x9B4)
Auto-selected AVI video ID = 0
AVI: Searching for audio stream (id:1)
XXX initial v_pts=0.000 a_pos=0 (0.000)
AVI video size=352370439 (64049) audio size=40937012 (40937012)
VIDEO: [XVID] 640x352 12bpp 25.000 fps 1100.3 kbps (134.3 kbyte/s)
Auto-selected AVI audio ID = 1
ds_fill_buffer: EOF reached (stream: audio)
dump: 40937012 bytes written to '/var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3'.
Core dumped
Exiting... (End of file)
boxee:~ ianedwards$ -
okay, that looks good, now please check if
exists.
call in a terminal:
1.
(press enter)Code:cd /var/folders/p3/wz4vwfmn6qld7qsyfh0k1xx00000gn/T/
2.
(press enter)Code:ls
and check if the output of that command contains:
Cu Selur -
Cleanup At Startup
Dancing.with.the.Stars.US.S14E01.HDTV.XviD-2HD.264
Dancing.with.the.Stars.US.S14E01.HDTV.XviD-2HD_18_19_44_641_02.stats.mbtree.temp
Dancing.with.the.Stars.US.S14E01.HDTV.XviD-2HD_18_19_44_641_02.stats.temp
Dancing.with.the.Stars.US.S14E01.HDTV.XviD-2HD__aid_1__18_19_44_641_01.mp3
HybridEDLFile.edl
MacKeeperUninstaller.app
MythBusters
MythBusters - 10x03 - Square Wheels_11_51_08_771_05.264
MythBusters - 10x03 - Square Wheels_11_59_27_341_05.264
MythBusters - 10x04 - Swinging Pirates DELAY -43ms__aid_1__10_42_11_531_02.aac
MythBusters - 10x05 - Battle Of The Sexes DELAY -43ms__aid_1__10_44_12_641_02.aac
TemporaryItems
com.apple.TextEdit
icssuis501
wda_18_29_07_951_01.stats.mbtree.temp
wda_18_29_07_951_01.stats.temp
wda_18_29_55_161_01.stats.mbtree.temp
wda_18_29_55_161_01.stats.temp
boxee:T ianedwards$ -
Nice, "MythBusters - 10x05 - Battle Of The Sexes__aid_1__10_44_50_541_01.mp3" is there -> give me half an hour to fix it in the code and upload a fixed version.
sorry, for the waiting, uploading took longer than I thought,..
please try the attached file,..
this should fix the audio problem,..Last edited by Selur; 6th May 2012 at 14:47.
That would be great, if it fixes the problem I'll release a new public version for all OSs in a few hours.
Still getting the same problem. I used the one package that you gave me.
Audio handling - custom. Under audio tab I did change anything but I did click on the + to add encode to queue.
I did notice that when I started the queue the audio encode took 0 time, I do mean nothing. I clicked start and pretty much jumped to video encode. -
Please redo the debugouput, and make sure to delete the old debug output file before,.. (it's a real pain to read 10k+ lines
btw. to speed up the process of finding the audio handling problem it might help to set video handling to 'ignore' while looking for the problem, this way the debug output is smaller and the whole processing is faster since no video handling needs to be done.
never mind found the problem:
"-threads 4 -y - i" should be "-threads 4 -y -i "
will upload a new version,.. -
man compiling Hybrid so often really is a pain,... (I have to think about buying a new mac this year,.. my mac mini really takes it's time,..)
+ if I move again to another apartment I will first check that there is a Internet connection which has more than 1MBit/s upload,..Last edited by Selur; 6th May 2012 at 16:03.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2394Last Post: 5th Jan 2026, 10:52 -
what hybrid cars should be
By deadrats in forum Off topicReplies: 0Last Post: 2nd Mar 2010, 19:48 -
Hybrid Car ??
By jdawson1960 in forum Off topicReplies: 19Last Post: 21st Nov 2008, 23:02 -
hfs hybrid
By cdenley in forum MacReplies: 4Last Post: 14th Aug 2007, 11:15
