Hello everybody.
I rip tv with Terratec H5 software is DVB Viewer
Mostly is soccer matches.
Lately there has bin a lot of deter-interlace problem
How do I remove this the best way or do you at all think it should be fixed?
I have used a lot of different programs to fix it but it really damage the quality, what is the best way?
Sincerely
JackDanielZ
Results 1 to 9 of 9
Avisynth plugins are better.
Yadif mode is fast but no high quality image.
QTGMC mode is slow but higher quality image.
Script QTGMC
DirectShowSource("video.mpg")
AssumeTFF() or AssumeBFF()
QTGMC( Preset="Slow" )
Claudio -
Preset="Faster" is still better than this + better use DGDecode/MpegSource or FFVideosource instead of using DirectShowSource with mpeg content,..
Why are you deinterlacing in the first place?
If this is for recording and watching on a TV, leave it interlaced.Want my help? Ask here! (not via PM!)
And if you're playing on a computer just use a player that deinterlaces on the fly.
De-interlacing will be lossy ,unless you de-interlace to a double frame rate ( i60 to p60 in America,or i50 to p50 in Europe ) (I don't know how to do so).
If you de-interlace to p30 or p25, you will lose fluidity ,and that's a trouble for sport stuff ...
So, play your videos as they are and use a player that can play interlaced stuff well.
Troubles may also come when you resize interlaced stuff.Last edited by misermidas; 18th Apr 2012 at 03:13.
Will BLURAY kill DVD?
By fjmr in forum Newbie / General discussionsReplies: 151Last Post: 29th Feb 2012, 11:27 -
Did they kill Stargate Universe?
By yoda313 in forum Off topicReplies: 12Last Post: 5th Apr 2010, 12:46 -
sony kill switch?
By deadrats in forum Off topicReplies: 8Last Post: 27th Jan 2010, 18:06 -
PgcEdit - kill pgc playback
By skaleton in forum Authoring (DVD)Replies: 5Last Post: 15th May 2009, 09:14 -
Just kill the power vice using shut down.
By Xylob the Destroyer in forum ComputerReplies: 24Last Post: 16th Jun 2008, 19:50
