I've had a problem for years where Adobe Premiere (first Pro 2, now CS3) gives me bad frames in most videos I export from the timeline using any lossless codec (Largarith, Huffyuv, etc).
I'm running XP SP3 with 4GB RAM. I enable the Windows 3GB application switch for maximum stability.
My clips are frameserved to the timeline using AVIsynth. I've experimented with the AVSplugin RAM settings but there's no solution there.
The problem can occur on both NTSC or PAL projects, on short 1 minute projects or a 90 minute ones, on both RGB exports and YV12 exports, and any size aspect ratio (2.35:1, 16:9, 4:3). There may be lots of bad frames or relatively few. I can't see a pattern to the problem.
Here's a sample of these junk pixels. They are nearly always in the top third of the picture, and usually black and white with bits of colour. The junk was once mostly green and/or red; more recently it's mostly black and white. Don't know why.
Here's snapshots of my typical Premiere export settings:
Please ask if you need more info.
Can anyone point me to a solution here?
What kind of CPU power do you have? Are your media files on their own hard drive, or are you editing footage on the same drive as your operating system? Deficiencies in those areas could be the culprit. Also, there are postings in various forums about Lagarith sometimes not working or playing well with Premiere, and indeed, I've had problems with it myself. After switching to HuffYuv as my lossless avi format of choice, it's been smooth sailing ever since. You might want to consider doing the same.
You can try UT Video Codec as well
I doubt this will affect you, but upgrade your lagarith , there was a bug fix specfically for Adobe in 1.3.26 (but it addressed crashes, not corrupted frames) . I believe 1.3.27 is latest
Version 1.3.26 released on 09-25-2011
Fixed a buffer overrun in the decoder that caused crashes with Adobe products. Thanks to the all the people that reported this bug.
Fixed an error that caused certain solid color frames from 1.3.20 and earlier to be corrupted.
If the preview in program monitor doesn't show corrupted frames, it's not an avisynth frameserver issue
Adobe Premiere Pro CS3 Write Initialization error when exporting
By dzsoul in forum Video ConversionReplies: 3Last Post: 21st Nov 2009, 19:23 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 15:15 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 08:54 -
Premiere CS3 bad capture results
By LSchafroth in forum Capturing and VCRReplies: 6Last Post: 15th Mar 2008, 14:17 -
Bad video quality when encoding in Premiere Pro CS3
By Rocky88 in forum EditingReplies: 2Last Post: 6th Sep 2007, 00:56
