hi
				Results 1 to 18 of 18
	Pro Audio To Go SUCKS
 Pro Audio To Go rip-off
 Pro Audio To Go garbage
 Pro Audio To Go identity theft
 Pro Audio To Go credit card scam
 Pro Audio To Go scam
 Pro Audio To Go drains the battery
 Pro Audio To Go security alert
 Did I forget any?
	You joined VideoHelp just to SPAM this app.....you didn't expect this did you?
	More detail needed on the "adapter". The video says it converts balanced XLR mics to unbalanced analog mic level. Similar "adapters" sell in the $50-150+ range.
 Why go though the analog input and how is this "48 KHz" CD quality digital audio? The analog input on a phone would be noisy.
 Alternate: The Audio Technica ATR2100-USB can connect to an iPad via USB and is seen by Garage Band or other audio apps. The path is digital. Total cost in the $49 range on Amazon. Downside is reported failure rate in user comments.
 http://www.audio-technica.com/cms/wired_mics/b8dd84773f83092c/index.html
 Last edited by edDV; 17th Apr 2012 at 00:24. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I don't work for the company nor am I paid or have any interest in their sales. I didn't intend to SPAM your forums but rather to see if anyone has heard of this app or used it for creating videos. That's all. Not the nicest first reply I must say...but you got your point across.
 I understand that's my first post and it looks as if I'm throwing this at you... I came on too strong haha My apologies. I'll edit it.
 However, I am using this forum just as anyone else in that Im looking to learn about creating videos. I myself am just learning and thought that this app would or could be able to get a decent recording to go along with my higher quality video from my DSLR (Nikon 3100).
 Just trying to gain everyone's general thoughts on recording with your iPhone.
	The XLR cord has a 3.5mm male end to connect to the phone, an XLR female end and a headphone jack. I think its under $30 so its on the lower end. Its in AIFF which you can send to your editing timeline via FTP or email and drop it in without a conversion.
 It doesn't support phantom power so there's no mic presets. It says it has EQ presets though. \
 I'm on the beginner side with audio so the above is pretty much what I learned from their website.
	hech54: I'm not denying anything here and I haven't been dishonest. I'm working on a school project and pretty much trying to find what markets this app works for.
 I'd be happy to discuss it further with you via pm as I'd like to keep this thread on topic. Thank you
	[/QUOTE]There is more to it than that. A quality low level balanced XLR to unbalanced mini-jack "converter" needs transformer isolation from iPhone DC and level step up. The iPhone is designed for high level high impedance mics. The analog path is low quality.[/QUOTE]
 How much noise are we talking about here? I understand that you aren't going to use any mics that require phantom power but that doesn't mean all's lost does it?
 How much noise are we talking about here? I understand that you aren't going to use any mics that require phantom power but that doesn't mean all's lost does it?[/QUOTE]
 Low level mics capped to iPhone will have high noise and distortion. Not "pro audio".Recommends: Kiva.org - Loans that change lives.
	I see.
 So the ability to record at 24 bit/ 48kHz is only half the battle. Is that what the mic presets do; tune out distortion and noise?
	I seriously doubt the iPhone analog mic input supports 24 bit A/D. Even if it did it would be capturing distortion and noise off a low level mic.
 You can find many articles on field recording via Google.
 http://www.ljclark.com/audio/audio-01.htm
 http://www.auditory.org/recorders.html
 The Zoom H1 ($89) is considered a good low cost performer.
 http://www.samsontech.com/zoom/products/handheld-audio-recorders/h1/
 http://www.amazon.com/Zoom-H1-Portable-Digital-Recorder/dp/B003QKBVYK/ref=sr_1_1?ie=UT...4640227&sr=8-1
	Cool, Thanks.
 The Zoom has come up more than a few times in other discussions.
  Phone froze while recording, HELP ME SAVE MY FILEBy boostjunkie92 in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2011, 14:41
  Fixing audio in a clip taken by a mobile phoneBy shorto in forum AudioReplies: 3Last Post: 23rd Jun 2011, 08:34
  Audio file (mp3) will not play on Nokia phone.....HelpBy efiste2 in forum AudioReplies: 2Last Post: 28th Apr 2011, 20:54
  recording audio using the ati tv wonder proBy cadams8221218 in forum Capturing and VCRReplies: 4Last Post: 22nd Mar 2009, 19:12
  I need suggestion recording cell phone voice messageBy videocheez in forum AudioReplies: 2Last Post: 7th Sep 2007, 16:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
