Shrug. Finally got tired of a certain media player (Popcorn Hour A300) almost invariably picking non-English audio tracks by default, and no option to correct this. The solution is to take that extra step to eliminate all non-English audio channels.
Thus far, I've been converting my DVDs to MPG files - primarily because of a bug with the PCH A300 which causes blackouts when watching any native DVD format. This process packages all the audio channels intact. What I need to find is a program which can take these MPG files, identify the streams, let the user pick which one(s) to keep, and spit out the result. As MPG.
MMG does this for MKVs. TsMuxer does this for M2TS, TS and Blurays. But I haven't found the app which can output MPG, same as what I start with.
Yes, I could simply convert the MPG to MKV or M2TS, but there are good reasons why I oppose this solution. The PCH A300 has sync issues with MKV. And M2TS (or any other) videos take longer to seek.
Thanks in advance!
I get where you're coming from. But you can either...
1) Admit that the PCH buy was, in hindsight (not your fault), a poor one and buy a better media player like one of the Western Digital ones. The money you spent on the PCH is gone. Letting that cloud your judgement is not your best plan.
- or -
2) Continue to paint yourself in a corner and do all this crazy crap to make the PCH behave like it should.
If you opt for #2, the old DVD Decrypter can decrypt most, but not all, current region 1 DVDs. You can use it in IFO mode (look for a guide) and pick which audio and subtitle streams you want and send the output to 1 large VOB file (go into the settings for IFO and tell it not to split the VOBs). The final VOB will have just what you want and you can convert to MPG with VOB2MPG. That method will accomplish what you want. Maybe someone else knows a better way, but you'd really be better off to just sell the PCH some way and get a better player that doesn't require all these extra steps. -
Another way is ffmpeg; and if the English track was the same # (e.g like always track #2), then you could even batch process them
Another way might be demux with dgindex, then manually select the elementary video + English track (since it will demux all tracks), then use muxman or imagompeg-muxer to re-wrap into mpeg-ps -
I didn't know DVD Decrypter could do that. And I used it a lot. That means I'm blind. ;/ It's too late now, though, because I already ripped everything and it's all either VIDEO_TS or MPG.
Nah man. I weighed the pros and cons and settled upon the A300 because it was the only thing that could play an entire Bluray ISO or folder, complete with full menus. Maybe that's changed in half a year, but it was a bad sign that WD was already behind the times. True, I am frustrated with the kinks which came with new hardware (older PCH devices don't have the two problems I've outlined), but I'd have been quite a bit more frustrated at not being able to play Blurays with menus without also bringing a Bluray player + discs in tow. -
Know a good frontend for ffmpeg? Particularly, one which operates more or less just like MMG or TsMuxer? The ones I've checked out both assumed I wanted to encode brand new video+audio, and completely lacked any stream selection. I was forced to assume that ffmpeg actually didn't feature such options.
ffmpeg is like swiss army knife. If you designed a GUI that covered all the functions it would be dozens of pages long with 100's of buttons and unusable
It's not a common task that you want to do, so I don't know of a GUI that fulfils this requirement similar to tsmuxer design -
The "MPG Tools" of the old TMPGEnc Plus can demux and remux, BUT they are somewhat limited
As a last resort, there will always be mplex.exe
WTV remux to MPG
By Nohajc in forum Video ConversionReplies: 44Last Post: 9th Aug 2013, 21:47 -
Remux to MPG
By LeChuck in forum Video ConversionReplies: 14Last Post: 25th Sep 2009, 11:19 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
