Results 31 to 36 of 36
Don't think levels are the problems, I would go for 'wrongly configured LCD display' (i.e. too bright)
Whether it's levels or too much brightness, the blocking on Van Damme's pants is something I doubt I'd notice viewing the video on my TV, not unless I paused the video or I knew the blocking was there and went out of my way to look for it. The same applies to the blocking on the brown alley wall. I have to send the TV the wrong levels or crank up the brightness before either becomes very noticeable.
If you're using a PC monitor to view your encodes it still could be a levels issue. Which version of Windows and which media player are you using? If your video card has a setting to change the output levels for video, what's it set to? If you can, try setting it to "Full range" or "RGB 0-255" (however it's labelled). If the video picture suddenly gets darker then your problem is probably (at least partly) levels. -
Well i burned the samples to a DVD and played them on my bluray and the blocks aren't as much noticeable as the pc but they are still there.
My OS is Windows 7 Pro SP1 and the player is VLC... The colors of my graphic card are already set to "Full". -
Use the video in this post:
https://forum.videohelp.com/threads/326496-file-in-Virtualdub-has-strange-colors-when-o...=1#post2022085
and your graphics card's video proc amp settings to adjust the brightness and contrast.
Black blocks/artifacts when viewing XVID on TV
By skribby in forum Newbie / General discussionsReplies: 4Last Post: 21st Feb 2012, 08:48 -
Blocky artifacts on authored video---what gives????
By unclescoob in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2011, 16:24 -
Blocky artifacts in video, part 2
By The111 in forum Newbie / General discussionsReplies: 11Last Post: 17th Dec 2010, 12:10 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
artifacts while playing xvid files
By greendesert in forum Software PlayingReplies: 2Last Post: 3rd Jan 2008, 11:42
