I'm looking for a video player that has a very detailed control panel.
The features i'm looking for are:
-can step forward/backwards a user specified amount of time each click(x seconds per click). Preferably able to hotkey to keyboard buttons
-be able to easily change between playing at 1x-around 100x normal speed with button clicks.
Anyone know of anything with these capabilities? Any help would be much appreciated.
Many can do what you mention - just a matter of how. The frame by frame probably won't be automatic (as in, click a button, then it auto advances 1 frame at a time).
VCL & SMPlayer may have the most configurable control bars (add icons). I think SMP can step forward / back. Believe VLC only steps forward (for 1 frame) - not positive.
I don't know they'll have 100x - why would you want to "play" that fast? Can't see anything. Why not just drag seek button or click on advance bar? -
MPCHC has single step forward and backward, jump ahead or backward in small, medium, and large increments, jump forward and backward to keyframes, and fast forward all with keyboard shortcuts. Speed is limited to 1/8 to 4x.
PotPlayer plays up to 16x forward.
You won't find a player that supports 100x because no player can decode the source video that fast. And backward playback usually isn't feasible because of long GOPs. -
mplayerc has multiple playback speed and v6489 will run on windows 98
Change video speed by 10X while retaining FPS
By a1745 in forum EditingReplies: 2Last Post: 15th Mar 2011, 09:40 -
WD player (can it play backwards ?) recertified ?
By Umen Pich in forum Media Center PC / MediaCentersReplies: 1Last Post: 3rd Jun 2010, 06:59 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 20:00 -
:?: half-speed play with no audio pitch change?
By gregconquest in forum Software PlayingReplies: 8Last Post: 10th May 2008, 22:21 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 06:12
