Hi,
Have just bought a new AMD 6 core PC with 8gig of 1600 ram
2 x 1 tb drives @ 7200 Motherboard is Asus M5 A99X
Win 7 64
Nvidia Geforce GT 440 card
I cant work out why I am dropping frames every 2 - 3 minutes with my Mini DV capture.
I am merely using the same software that i have been using on other PCs in the past without
any capture issues whatsoever.
Firstly I just completed 8 x 1 hour HDV tapes captured with Sony HD Movie Studio 11 ( Latest )
All of these went thru perfectly using my Canon XH A1 HDV camera
Then I tried a mini DV Tape.
dropped frames from the same Canon HDV / Mini DV Camera
dropped frames from Sony DVCam / Mini DV pro unit
dropped frames from cheap but reliable Canon Mini DV camera
All of these were using firewire from unit to PC.
Then I tried camera to AVDC100 using rca leads but also dropped too many frames
( about 500 frames dropped in 20 minutes. )
Then installed TMPGenc Video works 5 and got same dropped frames issue.
Then installed Vegas 8 and got same dropped frames using Canopus and direct
to pc with firewire.
I have been using most versions of Vegas for about 8 years now and capture
video for a living.
Yes I have clicked on update drivers in device manager and Win 7 tells me that I'm up to date.
Have I bought a motherboard or Graphics card with some known audio problems ???
I must admit that i don't know much about building a system, I just know how to sit
in the drivers seat and steer the mouse 10 hours a day.
Can anybody suggest any possible answers to this problem
Cheers
Results 1 to 10 of 10
Why is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system.
Are you installed all drivers that came on the DVD?
The windows 7 installs only the basic drivers with no acceleration.
Claudio -
Are you capturing to the drive that doesn't have Windows installed on it? On a new Win7 computer Windows is doing a lot of stuff with the boot drive in the background (indexing, defragmenting, downloading updates, etc.).
Have you tried WinDV for DV capture?
I routinely record DV from my ADVC-100 as a background task with no lost frames (Win7-32/Vista-32/XP-Sp3).
There might be a 64bit issue. That is why I stick with 32bit.
Avoid capture to OS drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks to everyone
Am not capturing to OS Drive.
Am not running any obvious background programs
Have tried 3 capture programs ( all are owned and not cracked and have worked
previously in my other PCs.
Have also tried 2 mini DV tapes that i know are clean and pristine in quality
It's after midnight here in Australia. Will wake up in the morning and reinstall audio
card drivers.
cheers
scottWhy is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system. -
Use this guide to optimize Windows 7:
http://www.ocztechnologyforum.com/forum/showthread.php?63273-*-Windows-7-Ultimate-Twea...l=1#post442151 -
Have just downloaded Win DV
2 questions please
Which AVI type is best 1 or 2
I am capturing Mini DV, Hi 8s and VHS etc. Will create MPG2 files later for DVDs.
Also noticed about 30 AVI files captured during the first 5 mins.
What is a good setting on the option page to have it capture 1 long AVI file
( assuming that this is possible )
thanks
ScottWhy is an intelligent man's vote, worth the same as an idiot's vote in a democratic election system. -
Type 2 is normal for typical editors (Premiere/Vegas/etc) but they can also accept type 1.
Type 2 DV adds a second audio stream copy. In the early days this saved CPU cycles required to separate AVI files into video and audio. As CPUs gained power this was no longer an issue but Type 2 remained the default.
WinDV tutorial
http://www.windowsmoviemakers.net/PapaJohn/61/WinDV.aspx
Discontinuity Threshold = 0 gets one large file.
1min = 25 fps x 60sec = 1500 frames.Last edited by edDV; 16th Apr 2012 at 11:44.
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Please help me stop dropping frames!
By justin81 in forum Capturing and VCRReplies: 28Last Post: 1st Apr 2011, 07:17 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 08:47 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 16:19 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
