Hi folks. This isn't really about file conversion, but frankly I don't know where this question fits in the forums; I've never encountered this weirdness before.
I have a 10gig MKV file that will not transfer to thumb-drive, nor external HD. It will transfer fine within the C drive, or to D drive no prob's.
All my thumbs are formatted to FAT32, as is the external HD. Seems bizarre, but is there something I'm missing? All I get for a message when attempting transfers is "the drive is full" or "not enough room on drive." Both msgs are complete bollocks.
Oh yeah, just bought a Philips BDP3406 for the express purpose of playing MKV and MP4 files, and watched two flics (3 and a 4 gig) with no transfer prob's at all.
Any help appreciated.
Cheers,
Wanderlustus -
The maximum size any single file can be under the FAT32 filesystem is roughly 4GB, I believe. You won't be able to copy your 10GB file as-is to any of the FAT32 drives.
Your BD player will probably accept a flash drive formatted to NTFS, though, so if you have a spare, empty flash drive with enough space, you could always format it to NTFS and see if everything works with the BD player.If cameras add ten pounds, why would people want to eat them? -
I did not realize this bit of info. Funny enough the file plays fine, and does transfer from C to D drive and vice versa.
The new player does except NTFS externals, so I think I'll have to give your idea a go with a thumber. I shudder at the thought of transferring a terabyte off my external in order to reformat it.
Many thanks. Now, if I just knew how to format it to NTFS. There's nothing in the XP format pop-up that supports it.
edit -- Oops. Just found it.Last edited by Wanderlustus; 15th Apr 2012 at 21:51.
Cheers,
Wanderlustus -
Right. 16gig thumber re-formatted to NTFS and transferring just fine. Perhaps I should've created this file directly within the external HD and I'd not have had this problem. Still, I'd not know what I know now. Thanks for sharing your wisdom, Ai. Not the first time you've helped me with a problem; I really appreciate it.
I love this site.Cheers,
Wanderlustus
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
What is the easiest way to transfer blu-ray to something like mkv?
By hannibal1 in forum Blu-ray RippingReplies: 11Last Post: 24th Aug 2010, 19:57 -
transfer programs across xp installs (on 2 different hard drives)
By greymalkin in forum ComputerReplies: 2Last Post: 17th Nov 2009, 05:11 -
Possible to transfer subtitles from MKV HD file to converted MpegII file?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 09:58
