i've created a dvd in dvd lab pro using the text labels as buttons for each video clip.
however, the longer ones (taking more than half of one row) can't be higlighted/selected in menu.
when i play the previous clip, then click next on my remote, the problematic video will play normally, but it can't be selected from the menu.
is there any way of solving this without shortening the text labels?
Never seen this, but post your problem here.
http://www.mmbforums.com/viewforum.php?f=10 -
i totally forgot about this problem; i've figured out the problem myself later.
it wasn't the length of the text but the text "buttons" were too close together, so the program couldn't link them properly.
if anyone has a similar problem, untick auto-route, then choose the direction icon next to it (up/down) and draw connections.
anyway, thanks for the reply.
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 20:06 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
How to create DVD menu buttons in Photoshop w/text only highlighting?
By rbatty11 in forum Authoring (DVD)Replies: 5Last Post: 30th Nov 2007, 20:58
