Results 1 to 1 of 1
    Apr 2012
    Skelton Saltburn Yorkshire
    Hi
    I am trying to do put together a Slideshow using , " DVD Slideshow GUI " , the problem is I keep getting a error message when I change the , " Transition " ie the fade in and out , it keeps saying , " The files you are attempting to play has an extension (.avs) that does not match the file format " .
    I have attached 2 screen shots , as you can see all the Transision extensions have a .avs . what am I doing wrong here .
    any help would be highly appreciated .
    cheers
    spike
Name:	error message slideshow.jpg
Name:	error message slideshow2.jpg
