i have encoded some dvd to mkv, my settings are 640x480 1250@29.97/fps. when i play them on my big screen using my htpc media center wich is core2 duo e6600 5gig's ram with an ati 5450 video card, they seem to be stuttering in certian sceens. any idea's?
thanks.
How did you do the conversion? What software?
Are they film content? Like Hollywood movies? Then you should probably have inverse telecine (remove pulldown) and the frame rate should be 23.976 . If they were derived from film (or digitial equivalent), then 29.97 would have a duplicate every 5th frame, so it would stutter
If it was interlaced content (like sports video), then dvd would be 59.94i . In motion scenes, you should have bob deinterlaced to 59.94p instead of 29.97. That would preserve the fluidity of the motion like the original.
Very rarely do you have true 29.97p content on a DVD (but it's possible) -
29.97 fps is your problem. You're probably getting blended frames or repeat frames.
i am converter star trek voyager original dvd's to mkv. i use makemkv and they make the frame rate is 29.97p, i then use xmedia recode and it reads them at 59.97p then i force it to it's orginal rate of 29.97p. hope this helps. good info.
thanks.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
DVD Encoding for WD TV
By kwanbis in forum DVD RippingReplies: 17Last Post: 17th Apr 2009, 12:00 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31 -
PAL HDV encoding DVD to play on all DVD/TV standards
By ivo in forum MacReplies: 7Last Post: 11th May 2007, 20:26
