I extracted the .ac3 file from a MKV (Used mkvtoolnix). The audio is "AC3 @ 192 Kbps 2 channels". I only saw the 1 audio file when I extracted it.
Now I want to split it and convert it to MP3 (or aac?). How do I do that without losing too much? Is the best way to do it is to convert it to MP3, then split it up? or Should I convert it to FLAC, then MP3 ? Not sure if converting to flac will do any good?
Also, which programs to use? if I convert to MP3 and split is Audacity good for this?
edit: When I say split, the audio is a 1 hr 22 min long audio file. I just want 3 minutes of it taken out and put into a MP3 file or whatever
well, its for playing the song on my ipod/phone? For my computer/home entertainment, I can keep the ac3 file. or am I missing something?
Originally Posted by jaesun
Edit - you can keep the original ac3 file. Just copy the new mp3 file with itunes to your iphone.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
well, its a 1 hr 22 minute long audio file. I only need 1 song out of it, so I need to split it, then convert it to whatever.
edit: hmm, maybe you think split, as in split out the channels and take that? yeah, I didn't mean that, sorry. I just want a song out of it that I cannot find anywhere else. -
OK
Do it the other way round.
First convert the ac3 file to mp3 with WinFF from here ---> http://winff.org/html_new/
Then cut out the one song with mp3DirectCut from here ---> http://mpesch3.de1.cc/mp3dc.html
Remove Channel from .ac3 5.1 audio
By 557953 in forum AudioReplies: 9Last Post: 22nd Mar 2012, 04:19 -
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
Splitting AC3 48Hz 2 Channel into 2 seperate files
By Caliburner9 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2011, 22:51
